Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Cruise control feature
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Cruise control feature
    Has anyone noticed that if you set the cruise control at a speed and then manually increase vehicle speed by pressing the accelerator pedal, after a few minutes the cruise control will switch itself off and the light on the dash goes out.
    Jan 2006
    Skynet HQ EMEC#5
    Yes, mine does that as well
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Yep me too. I haven't worked out if there is a time element, but there is a speed element in that if you increase speed by 20MPH over what the cruise was set to, it switches off.
    Most noticable in roadworks when I've set it for say just under 50, then accelerated up to 70 once clear.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I'll have to have a look - I have noticed you can't set it immediately after starting the engine & driving off - I don't know if down to a certain length of time, distance or maybe engine temp but it certainly won't switch on for a few minutes!!
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Never happens on mine. I often put my foot down when in cruise and it always goes back to the pre-set speed when I lift my right foot.
    Regular Member mc_orion's Avatar
    Aug 2007
    Worcester...and most motorways!
    Gonna have to see if that happens...only just noticed a small shelf under the steering wheel this morning!!!!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, the road works thing is when i noticed it.
    I can set mine immediately when setting off and reaching the minimum speed allowable.
    You have to keep above the set speed for a while, I estimated about 3 minutes before it cancels. (or maybe it is speed de-activated)
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Quote Originally Posted by Ian S100 View Post
    the brake needs to be pressed before CC activates
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by LJ sxi-nav View Post
    Not on mine. I don't know about others though.
    Winchester
    Quote Originally Posted by Ste View Post
    vectra 2003 manual states:
    "For safety reasons, the cruise control
    cannot be activated until the foot brake
    has been activated once."
    Thought mine was broken recently, set off from a carpark, clear run to the main road, quickly up to speed and CC would not turn on at all, only after I touched the brake could I activate it.
  1. Cruise Control :(
    By paddyvectra in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 01:26
  2. Cruise Control - DONE
    By wotsthestory in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2010, 19:32
  3. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  4. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
