Thread: car with spanner through it
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    Default car with spanner through it
    had a quick search but can't really see anything. iv'e got a pre-facelift 2.2 direct vectra petrol,noticed yesterday when i accelerated hard she misfired at about 4,000 rpm in 3rd. well today same again and then the car with a spanner through it has come on have turned ignition off and on again twice but no luck,will disconect battery now and will report back later any advice though will be greatly recieved.
    martin.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i had a misfire on my 3.2 and took it to be tech 2'd and they told me next time i thought it was just a misfire to disconnect the battery first and see if it appears after that. if it does then its something other than a misfire and needs to be tech 2'd if that makes sense!!!
    Regular Member TomiboyC's Avatar
    Aug 2007
    East Ayrshire
    Had this problem on my previous 05 vec with the same engine, turned out to be the fuel pump which at the time seemed to be a common problem as it took almost a fortnight to obtain new pump due to the shortage, car would also cut out without warning which led to a few hairy moments on motorways! so beware!
    Nov 2007
    telford,
    cheers chaps just gone and had a looksey again and it has not appeared. seems to have gone started her up four times and she seems ok with the car spanner light no longer showing. have taken battery off and putting it on charge whilst its off.
    Feb 2007
    be careful mate cause it might show up when you are driving it not just starting it up!!
    Nov 2007
    telford,
    think i mite take it for a spin see what happens.
    Nov 2007
    telford,
    just done 15 miles very very quickly and seems fine will see how she is over the next couple of days.
  1. Help - Spanner, then no spanner!
    By Ricksh in forum Engine & Drivetrain
    Last Post: 1st October 2012, 12:04
  2. Spanner
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 20:09
  3. car with spanner going through it?
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2010, 13:00
  4. My spanner is always on.....??
    By smiley-sri in forum Engine & Drivetrain
    Last Post: 1st October 2009, 18:54
  5. Oil can with spanner
    By Darryl2.2DTI in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2009, 01:14
