Thread: Amazingly simple home remedies
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Default Amazingly simple home remedies
    1. IF YOU'RE CHOKING ON AN ICE CUBE, SIMPLY POUR A CUP OF BOILING WATER DOWN YOUR THROAT. PRESTO! THE BLOCKAGE WILL INSTANTLY REMOVE ITSELF.
    2. AVOID CUTTING YOURSELF WHEN SLICING VEGETABLES BY GETTING SOMEONE ELSE TO HOLD THE VEGETABLES WHILE YOU CHOP.
    3. AVOID ARGUMENTS WITH THE FEMALES ABOUT LIFTING THE TOILET SEAT - USE THE SINK.
    4. FOR HIGH BLOOD PRESSURE SUFFERERS ~ SIMPLY CUT YOURSELF AND BLEED FOR A FEW MINUTES, THUS REDUCING THE PRESSURE ON YOUR VEINS. REMEMBER TO USE A TIMER.
    5. A MOUSE TRAP PLACED ON TOP OF YOUR ALARM CLOCK WILL PREVENT YOU FROM ROLLING OVER AND GOING BACK TO SLEEP AFTER YOU HIT THE SNOOZE BUTTON.
    6. IF YOU HAVE A BAD COUGH, TAKE A LARGE DOSE OF LAXATIVES. THEN YOU'LL BE AFRAID TO COUGH.
    7. YOU ONLY NEED TWO TOOLS IN LIFE - WD40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
    8. REMEMBER - EVERYONE SEEMS NORMAL UNTIL YOU GET TO KNOW THEM.
    9. IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM.
    3.2 v6 Signum and loving it
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Quite good
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    good ones
    Jul 2006
    5,6 and 7 made me chuckle
  1. Newbie...came looking for remedies
    By Exxentrix in forum Introduce yourself.
    Last Post: 28th February 2010, 18:58
  2. Amazingly Simple Home Remedies-#3 is awesome!
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 18th November 2008, 15:33
  3. Hayfever Remedies???
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 24th June 2008, 21:03
  4. Field remedies
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2006, 17:50
