Thread: spanner light and the stealers
    Regular Member tankman's Avatar
    Feb 2007
    NORTHUMBERLAND
    Default spanner light and the stealers
    hi guy's can someone put right i turn the key and a spanner light pops up but go's out when it fire's up the stealers have said they is no fault code's on the tech 2.but hers the thing they have had this car twice before and 2 code's pop up one for the air mass meter and the other was a fuel pressure reg. my problem is 30 days my warrenty is out.any help 1.9cdti 2005 sri
    Regular Member Joeblack's Avatar
    Doncaster
    If the spanner light goes out when you fire it up it means there has been a fault recorded but the fault is no longer there, the spanner light will clear itself after so many starts where no fault occurs.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Which spanner light? 'Spanner and oil can' = service due indicator. If it's 'spanner and car' then there is a problem that should be investigated under warranty......or am I being daft?
    Doncaster
    If the spanner and car light stay on when the engine is running there is a current problem, if it goes out after the engine has fired the fault has cleared but a fault code has been stored - you can get the dealers to read the code but this happened to me a couple of times and when i took it to the dealers they said there was no fault code there... the spanner light will disappear from the ignition being switched on after so many "good starts"
    Regular Member djr69uk's Avatar
    Midlands
    is this the sort of stored error that a cheapo halfrauds style FCR can read?
    Regular Member TKD Colin's Avatar
    Jan 2008
    london
    "spanner and car" light comes on when you first turn on the ignition and it then goes out after about 10 seconds or so, the manual says that this is of no significance (p156) This is on pre facelift models.
    It kept doing it on my 03 DTi so i had it tech2'd just to see if there were any faults recorded and there weren't. However it later turned out that i had problems with my glow plugs and this was causing the spanner and car light to come on.
    might be worth getting you glow plugs checked
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  3. Battery Light plus stealers having a laugh!!
    By calbert07 in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2010, 22:52
  4. Alternator light on - In to the stealers tomorrow
    Last Post: 4th March 2009, 15:32
  5. Anyone know how much a smoked 3rd brake light costs from the stealers?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2008, 22:12
