Results 1 to 10 of 17
Thread: Help just got a signum/Nav on safe?
    Regular Member waltz's Avatar
    Mar 2007
    alloa
    Default Help just got a signum/Nav on safe?
    Hi
    Looking for help just got a 06 55 Signum today and the nav/radio display
    is on safe got the code for v/hall today but how do you get it in to the
    radio still works and the cd.
    Also the unit has a peak in the middle is this from a astra or are all vectra
    and signum units the same as astras
    Thanks Alan
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    safe means the radio or the display are either not paired up together or one or the other is from a different vehicle. Need to get them to try and tech2 both the radio and display and see if they like one another, 55plate cars dont requires physical codes like you used to input via the front panel but require the dealer to do the above pairing with tech2
    As a sidenote, where did you purchase the car from? it should be down to them to sort this out.
    Mar 2007
    alloa
    Private sale
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Oh dear,HPI Checked? If not start checking the Vin Number etc...
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Sounds more like he had a faulty radio or display and bought one from ebay without checking to see if its been put back into 'delivery' state and if it had then hes not had it paired up together. Hopefully the dealers will be able to tell you for sure what the situation is.
    Here, there and every where!
    Nope! Vectra/Signum radio fronts are slightly curved m8
    Looks like a Corsa/Astra headunit has been installed and should have been Tech 2'd out of the donor car and then it could be paired to yours.
    Could be an innocent swap but i'd be asking questions of the seller
    Mar 2007
    alloa
    So if i take it to the dealer they should fix it all
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    no, but they would be able to tell you if they can but only by trying it! probably charge you half hours labour for the priviledge
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    It looks like someone installed a CD70 from an Astra (Zafira/Meriva..) which has been unpaired to your Vectra without pairing it again.
    With some luck a Vx-dealer will be able to pair it via tech2: for that he needs your VIN and car security code;
    the front can be replaced with one from a Signum/Vectra unit
    Quote Originally Posted by waltz View Post
    Hi
    Don't get this. If SAFE is being displayed, why does the radio & CD still work?
    Also, how did you manage to obtain a code from Vauxhall when there isn't one?
  1. keeping your car keys safe! really safe
    By nicj in forum General Chat
    Last Post: 10th November 2012, 15:15
  2. Safe
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2011, 02:30
  3. 05 vec sri cd player saying safe????
    By jaff in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2008, 22:56
  4. Is it okay to / safe to
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2006, 11:15
