Results 1 to 10 of 21
Thread: Tuscan or Cerbera?
    Regular Member JCB's Avatar
    Oh, I forgot to remember!
    Default Tuscan or Cerbera?
    simple one.....
    or
    chalk and cheese really. If you want a lightwieght sharp handling car with a porsche equalling performance, from a raspy 6 cylinder, choose the tuscan. If you want a big V8 to take on the likes of a DB9, then the cerbera is the weapon of choice.
    Personally, i'd choose the cerbera as i have more chance of getting the pram in the boot
    And just in case you wanted one, heres a TVR approved used one for less than vectra VXR money
    Model: Cerbera Speed 6
    Registration: W
    Trim: Half Hide
    Interior colours: PORTLAND GREY
    Mileage: 49,000
    Optional extras: PAS, Air Conditioning, Full TVR Service History, CD Player
    Price: £19,750
    Authorised dealer: Peter Smith Sports Cars, Station Road, Hatton, Derby, Derbyshire, DE65 5EL
    Tel: 01283 813593
    e-mail: db@petersmithsportscars.com
    Website: www.petersmithsportscars.com
    Well if you are having the cerbera Andy I`ll have the tuscan. Job`s a good`un ..
    Very gentlemanly of you JCB !!!
    Wiltshire
    TVR? No thanks!
    http://www.cerbera.co.uk/cerbera/problems_frameset.htm
    Here's an extract from the above site
    My own car has had the following warranty work at the mileage indicated
    3,600 Radiator core was leaking. Modified door pin switches fitted. They are now a sealed unit. Fuel Filler neck was rusted up underneath. Drivers window motor replaced as it was slow.
    3,900 Leaking union from oil filter take-off tightened.
    4,650 Battery replaced as it wasn't holding sufficient charge.
    5,500 Modified steering wheel mounting boss fitted. Windscreen cracked out in sun.
    5,800 Oil pressure switch failed. Windscreen washer fluid hose melted in two by the expansion tank outlet pipe.
    6,000 Changeover to Mobil 1. Windscreen replaced - 3.5 hours to get it out & 5 hours to get it back in. Oil pressure switch replaced.
    6,700 Second radiator fitted. Leaks from thermostat boss repaired. New passenger door top & bottom hinges fitted to alleviate stiff opening but it was worse ! Air con temperature adjusted.
    8,400 Second windscreen ordered. 2 top rear wishbone bushes replaced. Resealed offside cam cover. Resealed brake & clutch covers & wiring grommets.
    8,800 Has begun to stall after restarting the engine after it has been stood for 20 to 60 minutes.
    9,750 Had second windscreen & magnetic proximity door switch kit fitted. Rear shockers have begun to knock.
    10,120 Rear shockers, rear anti roll bar mounts & ice warning thermistor replaced under warranty.
    10,450 Back to the factory for the 3rd replacement screen, carbon fibre a-post covers & a set of later, Double Bubble, door seals. The early aluminium air-con fittings were replaced as a precaution with the later steel versions. Air con re-pressurised & the anti-ice valve set to 3 to 8 degrees. Many of the rusty fixings under the bonnet were replaced with shiny stainless versions. Driver's magnetic proximity switch adjusted.
    11,050 Back again. Both rear wishbones replaced as one of the ARB drop link supports which are welded onto the wishbone had cracked. Crank oil seal replaced. Wind noise & door problems still there.
    12,500 NEWNEW Still having problems with the doors not shutting properly
    ^^^yeah, thats why you buy one with more than 12,500miles on the clock...plus THAT noise!?!?
    There's this Tuscan in a Garage a couples of miles from my house...want to take it for a test drive...but too scared... http://www.ggsteel.co.uk/
    every car has it faults
    At least with a cerbera you get a free 12" Pen!s (why is P E N I S blocked out? lol) extension and a young bird who only loves you for your car
    Wiltshire
    The web page that was from hasn't been updated for a few years. The owner probably pushed it off a cliff and bought a Skoda Estelle with the insurance money!
    Regular Member Tim2100's Avatar
    Walsall
    mmmmmmmmm TVR
    I really really want a TVR.........
    For me would have to be the Tuscan.
    TVR Chimera's are down to sensible money now!!
    Darlington
    Cerbera speed 6
    looks the DB,s sounds awesome
    lets face TVR havent, got the best relibilty record
    and how many people use these cars for everyday use? maybe only a small %
    they a top fun car
    this is the only non GM car i would own
    I LOVE TVR's .. Always have and always will ..... my mates had two .. the later being the cerbera 4.2 360 bhp 6 cylinder monster 0-6- in 4.4 secs .... bloooooody ell it was quick !!!!
    but you do have to have a bottomless pocket to run one .... clutch replacement £4000 ish
    but they do hold thier value .... which does make a difference !!! especially compared to a veccy c
  1. 3 Laps around Donnington in a TVR Tuscan
    By Innes in forum Games Room
    Last Post: 4th August 2011, 19:34
tvr tuscan fitting door switch
