Results 1 to 10 of 16
Thread: Which Oil?
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Which Oil?
    Been looking for prices for an oil and filter change:
    One local Dealer quoted £45 another £49, this includes a 10 / 40 oil.
    Is this correct for the CDti 150 engine as I thought it was th 0 / 30 oil.
    Plrease help
    Kent, UK
    Errr... that seems really cheap - I can only just buy the oil and filter that cheap, let alone the change as well.
    Jul 2006
    Needs to be 5W30 semi or fully synthetic. Make sure you're getting at least semi synth or your engine will NOT be impressed.
    HTH
    Full Member Big Sig's Avatar
    5-30 mate, yours is an auto so will probably have a DPF. The right sort of oil is vital mate. The 10-40w is cheaper....... silly dealers.....
    Feb 2007
    North west
    5w/30 Mobil 1 epo (extended performance oil) with a filter change.
    £45 from quick fit for a CDTI - you have to ask for an oil upgrade service.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Is it OK to use the 10-40w oil?
    Regular Member jonesy_ni's Avatar
    Co Antrim
    I wouldnt be using it, i would def be getting the 5-30
    Jan 2008
    Lucenec - Slovakia
    Quote Originally Posted by Davidjs68 View Post
    I think its better to use fully synthetic oil which passes Opel/Vauxhall GM-LL-B-025
    (for "longlife" - approx. 18500 miles), like some 0W-30 ; 5W-30 ; 0W-40 ; 5W-40
    oils (I'm using Castrol's EDGE 0W-30) - for any diesel engine.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    10-40w was put in my last service is it OK now to change it to 5-30w?
    Jan 2008
    Lucenec - Slovakia
    Absolutely. The 5W-30 is better.
