Thread: not so much a part number but fault code
    Regular Member DAVO's Avatar
    Nov 2007
    WEST MIDS
    Thumbs up not so much a part number but fault code
    Sitting here at Micheal Wood services on the m5 the poor AA man cant find this code P1109?. Any body got any ideas.It wont allow me to pull above 2000 rpm and theres no smoke when under load.Cheers
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    P1109 IAT - B Sensor Intermittent
    hope that helps m8y
    Regular Member installer's Avatar
    Nottingham
    Quote Originally Posted by DAVO View Post
    "subject - Engine Z19DTH/ J - Intake manifold, swirl flaps, actuator out of order, DTC: P1109, P2075 set"
    "Customer complaint about lack of power and SVS lamp on. The following trouble codes might be set based on the installed application: a.) EDC16 C9 (2-actuator strategy, i.e. pressure sensor as well as pressure regulator fitted at fuel rail) TECH 2 shows DTC: P1109 or sometimes P2279(11). b.) EDC16 C39 (1-actuator strategy, i.e. only pressure sensor fitted at fuel rail). TECH 2 shows DTC: P2075."
    after a quick look on a certain vxl programme
    a direction is all I can offer
    Nov 2007
    WEST MIDS
    Thanks for the info.
    Sorry havent posted earlier only just got in from trip in a low loader.Will use the info 2moro at the stealers. Any body know if this is covered on the warrenty.....car is 06 i extended the NETWORK Q and is under 60k (43k) Any info would be a great help
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Manifold should be covered mate.
  1. Finding part number and code, HELP
    By ScotsDragon in forum General Motoring Chat
    Last Post: 20th March 2012, 16:37
  2. CID Part number
    By slipperysam1984 in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2010, 01:02
  3. Part Number
    By smoggydovit in forum Bodywork & Interior
    Last Post: 17th July 2009, 16:25
vauxhall fault code p2075
