Results 1 to 10 of 15
Thread: griffin removal
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default griffin removal
    hi all just in the process of removing that awful griffin! however the badge came off no problem i cant get the glue off the boot ive tried tar remover and wd40 but nothing will shift it! any ideas would be appriciated!!
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Just keep going at it.. it will go in the end. Try soaking it in hot water first, that's how I got mine off.
    Feb 2007
    cheers mate im doing the hot water aswell!! didnt realise it would be the glue that would be the problem! i was more worried about the badge but that was a doddle!!
    Regular Member Paulsvectra's Avatar
    Northumberland
    The badge is the easy part I just used hot wat and tar remover it took about 10 - 15 mins ..............well worth it
    Paul
    Feb 2007
    managed to get the glue off with the tar remover but still have the outline of the badge which i cant get off any ideas?
    Northumberland
    Try a little t-cut
    Paul
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Have always used white spirit,apply to the top of the glue with a cloth,wait 5 mins to soak in then start pushing off,followd by a small application of t cut scratch remover to get rid of the shadow,then a good resin wax,job done in half hour tops.
    Regular Member cookiejar31's Avatar
    Jan 2008
    leicester
    try using a hairdryer on it for few mins not to close and then start to peal off the glue. did all the badges on the back of mine in about 10 mins and never left a mark. after the glue is off just use bit of T-cut over it n jobs done.
    West
    Quote Originally Posted by cookiejar31 View Post
    Same here matey, hair dryer is always better than pouring boiling water over the paint work IMO
    Jul 2006
    Quote Originally Posted by vectragsi3.2 View Post
    Give the 'shadow' a quick once over with whatever polish you've got handy. I had the same problem - 5 mins with some Autoglym Super Resin Polish and you couldn't tell it had ever had a badge
  1. Replies: 2
    Last Post: 21st August 2011, 11:38
  2. New griffin
    By melo in forum Styling
    Last Post: 5th March 2010, 13:43
  3. the new griffin
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2008, 19:30
  4. The Griffin is gone
    By tonyt in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2008, 22:36
  5. Red griffin
    By ed taylor in forum General Chat
    Last Post: 30th June 2006, 16:57
