Results 1 to 10 of 15
Thread: Tyre load ratings for Vectra 3.0 CDTi
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Default Tyre load ratings for Vectra 3.0 CDTi
    I have just discovered that my 3.0 CDTi Vectra was sold to me with 91Y (standard load) tyres on it.
    It is a well publicised fact on this forum that the 3.0 CDTi should have 94Y or extra load tyres fitted.
    I plan to have a row with the stealer tomorrow but before so I was trying to find where in the manual it says what tyres should be fitted - I could find nothing. Can anyone help me locate this info?
    Lastly, what problems am I likely to see if I keep the normal load tyres on my car, bearing in mind it has been on them for the last 14 months??
    Mark
    Here, there and every where!
    Yup, Extra load rated tyres are needed due the weight of the engine.
    If you have an accident you may well find the insurance would not pay out.
    The 3.0 V6 CDTI is actually insured on the standard load ratings, you can replace the 95W with 91V
    Details are in the kerb weights index
    However, if you are using the 3.0 V6 CDTI to its design limit, then you really need to stick with the XL tyres
    One of my local police forces also have several such cars and these too are all on the XL tyres
    I was stopped for a tyre check a few months ago and the officer spent 40 minutes going over my front tyres, as he had never seen the specification and we had quite a conversation about it!
    The tyres were down to 1.6mm on the shoulders and 1.0mm in the centre
    After some calculations it was found that the XL tyres have a further 2.5mm of construction material
    The confusing point was that they were 225/45ZR17 on 94Y, in effect the ZR overrates the Y load rating, and they really should be 225/45YR17
    Aug 2007
    Kent
    Thanks chaps, I still cannot see where it explicitly states that the tyres should be extra load in the manual - need to have another better look but I could not see them with a cursory glance. I will have to wait before I speak to the stealer.
    I guess the only thing is to wear them out quickly and replace with XL GSD3's.
    Full Member Big Sig's Avatar
    91w etc is just within the weight limit of the 3.0V6 CDTi, but I think the auto is too heavy for them. Its just good pratice to have XL rated ones on as it is so close to the tyres limit. HTH
    Aug 2007
    Kent
    So, the dealer did not make a mistake by selling the car with normal load tyres on it. He was just running the tyres towards their limit - saving money in the process.
    Basically yes I think so. The dealer that sold me mine did the same. I'm not sure what rating they left the factory on, maybe look at a new or nearly new one somewhere and check its tyres?
    The tyres mine came with were also 91W rated but when i put the 18's on i asked for the extra load tyres. For the couple of quid extra it is not worth the risk. What value can you put on your family as they are the ones at risk should the worst happen
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    just checked mine and they are 91w but i am due two front tyres so it might put 94y's on.
    I'll echo what Caterman said. When my tyres are due for changing, XL's will be going on.
  1. tyre load index
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2011, 21:26
  2. Tyre load ratings.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 00:22
  3. Tyre Load Rating?
    By Grimy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 22:17
  4. Tyre load index
    By Roadhog in forum Handling & Braking
    Last Post: 28th April 2009, 09:53
  5. tyre load calculator
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2009, 08:20
