Thread: droning sort of noise from back end?
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    Default droning sort of noise from back end?
    as above really
    Driving along at any speed and i've noticed a sort of droning/whining noise from the back end of my 54 plate sri.
    I've only had the car about a month so would like to get it sorted whilst still under warranty
    any idea fellas?
    when i got the car it got a full service and MOT from dealers.
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    I had something the same today,seemed to stop when I let the mother in law out Sorry
    Apr 2008
    North East
    Quote Originally Posted by fenderguitar View Post
    nice one
    11 Post(s)
    Does it get any louder / quieter when going around bends?
    Sign of a wheel bearing failure if so.
    Also, what tyres you got fitted? Certain makes can be noiser than others.
    Apr 2008
    North East
    it doesnt get louder when going round corners
    funny thing is, coming to work this morning and the noise wasnt there
    feel the inner edges of the rear tyres.. if they are slightly 'stepped' they will whine like a bearing... the bearings make a similar noise but you can check them if you take the disc off and feel the smoothness of rotation by hand..
    Feb 2007
    Wales
    Default Check Out
    My entries on the site as I have also had a whine / drone from the car - seemed to be the rear
    Have played around with the tyes
    Checked the body work
    Checked under the car
    Have now had new rear discs under network q
    But still this odd sound that starts at 60 mph
    Still no idea
    My car is a new shape design 120 cdti 5 door
    My other car a new shape elite 150 5 door does not have the problem
    Vauxhall Dealer wanted to charge an hours labour to localise it even though the mechanic had heard it on its recent full service test drive
    Regular Member marcdale's Avatar
    May 2006
    Bristol
    I had exactly the same problem, the noise is coming from the tyres as mentioned by "GSi3.2". The problem was diagnosed as being the rear camber which needs to be adjusted by some where local to you who can do "computerised 4 wheel geometry". NOT TO BE CONFUSED WITH A QUICK CHEAP TRACKING ADJUSTMENT THAT THE CHEAP TYRE PLACE AT THE END OF YOUR STREET CAN DO. You need to look for something similar to ProTyre near you www.protyre.co.uk.
    You also need to be very carefull with your tyre pressures if you using wide wheels. Running them too hard with also cause the tyres to step on the rear. I'm running 19" alloys using 235/35/19 tyres and I have to run them at 33psi to avoid wearing the middle treads to quickly on the front and to avoid stepping on the rear.
    If you search for my threads you'll see one regarding this with photo's etc.
    Please be aware - your rear tracking may be out if your rear strut's or springs are worn out also. Depending on mileage or if you spend most of your time off road...:-)
    Feb 2007
    Wales
    Default Tracking Checked
    Hi Marchdale
    Thanks for the info
    I will get the car checked
    But interestingly the car has had its 4 wheel geo checked twice now once by a local specialist I use for tyres ( they do all the tyres for the local dealers eg Audi, Saab, Lexus etc in Cardiff ) and also by the Vaux Dealer who also has the kit as a body shop crash centre
    But still the drone is there but I'll mention it to them and see what they say
    Any other tips much appreciated
    Daft question but would they not have picked up the wear on the struts and springs on the service?
    No off roading for me, but even the on roading these days with the state of the roads looks like a rally stage
    The cars done 33k on a Nov 55 plate and its mainly done on dual carrageways
    Pressure are stated as 33psi for the car and are checked regular
    Will check with tyre centre / dealer on getting the camber checked again
    As Ever its all time off the road , why they dont train staff up or take a bit more time on checking a car during a full service I dont know, it would cost more but I'd be happy as it would mean less time drinking rubbish coffee at gargae
    Feb 2007
    Wales
    Default No Joy
    I have now had the cars suspension and 4 wheel geo tracking Checked and nothing was found
    I must say I do like Vekies as well I have 2
    BUT
    Is it just the fact that
    1. Garages ( not just dealers ) cant be bothered to actually offer a real service now
    2. Car to complicated
    3. Technician Training needs looking at
    Or are Vekies just not thought through as a design at the start of their life
    as they are nice cars but I have found ( now with 2 - this makes 3 in the last 5 years ) they suffer with not minor problems that quickly become big £ ones
    Thankfully the other Vekies Turbo was replaced under warranty but the delear did not give me confidence in the car as they have no idea why it failed as the Computer ( well did not say no as such ) did not offer them an answer
    Looking around now at other brands
  1. Droning noise from front - not bearing
    By Marc 100 in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2011, 22:11
  2. drumming/droning noise
    By paulb70 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 15:31
  3. Droning noise
    By HHH in forum Engine & Drivetrain
    Last Post: 18th June 2010, 20:36
  4. rubbing noise/droning ?
    By bigmac in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 10:54
  5. droning noise when reversing
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2009, 08:52
vectra c whining noise at rear
