Thread: diesel Fuel filter
    Regular Member PeteRs's Avatar
    here or there
    Default diesel Fuel filter
    i have the spanner light on & cant reset tried battery off for 30 mins it still there in the manual it says that on diesel engine Z19 it could be fuel filter need changing where is the filter & is it easy to get at car done 20,000 miles now so is it due service as theres no service me light coming on thanks
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    Spanner Light comes up if any of about 600 fault codes are present, not just the fuel filter It means there is a fault which is present and live and needs a Tech2'ing to see what the code is. Oh btw, the light wont come on when the filter needs changing but maybe when the water in the filter reaches a certain level.
    here or there
    maybe i'll ask if dealer can check it then when handbrake gets done when its happened before i could turn the light off but it wont go this time car drives ok
    as long as it drives okay then the codes not too serious..
    as my old dad says, it's TECH2 time..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Out of interest, when was the water drained out of the filter last?
    here or there
    got no idea car done 20K & is 3 yrs old how do i find out what servicing been done its on vauxhall computer as being serviced by dealer but got no print outs
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    you can drain it yourself easily. There is a drain on the bottom, just unscrew and catch about half a cup full and see if it's water or diesel....
    May 2008
    Cornwall
    Quote Originally Posted by Ste View Post
    I have the spanner up when the ingition is on but goes out when it is running although it came on first when driving. I stopped straight away, turned the engine off and then it started fine and noe only shows as stated above. Was going to drain the filter to check for water. To make sure is it the black cainster behind the engine.
    Any help appreciated.
    1.9 CDTI 120
    yes, the fuel filter is the black canister on the bulkhead.
    the light on the dash is just a reminder that it had a small fault, but that it's cleared.. it may have nothing whatsoever to do with the diesel filter thou.. a code reader is really needed to see what has actualy occured..
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Mark is right, it may not be anything to do with the filter, but if it hasn't been drained then it's something you can do easily and can only help - as it should be done periodically anyway.
  1. Air in the fuel filter on 3.0 V6 Diesel - Help!!
    By NPS in forum Engine & Drivetrain
    Last Post: 25th October 2012, 18:25
  2. diesel fuel filter
    By jpdtm in forum Engine & Drivetrain
    Last Post: 6th October 2009, 20:59
  3. Diesel fuel filter
    By john1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 23:29
  4. How do you drain the diesel fuel filter of water
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 11:04
  5. Diesel fuel filter
    By Trhains in forum Engine & Drivetrain
    Last Post: 28th May 2007, 16:44
diesel fuel filter drain vauxhall vectra 120 site:www.vectra-c.com
