Thread: Changing plugs on 1.8 vvt "06"
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Changing plugs on 1.8 vvt "06"
    Cant find a "how 2 " on this, and will be attempting this shortly, so want to ask opinions & get some help. Bearing in mind the last car I had was a cavalier and all I had to do was whip off the ht leads and there they were!
    Firstly, the metal bar that covers the coil pack is held on by two bolts at the back that look like they need an alan key, one end of this bar has a black plastic screw, which I cannot see a use for, and the other end has something connected to it, what?
    secondly, I have been told that I need to take the black plastic jobbie off? is this true?, if so why & how, as the bar is visible behind the big plastic jobbie.
    My last concern is loosing the rubber out of my socket after screwing the new plug in, previously I could reach it with my fingers on the cavalier, now with a long bar on my socket this wont be possible!
    Any helps or tips would be appreciated.
    Jan 2006
    Hornchurch
    very easy on the 1.8 lump
    you will need a torx bit set
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    do a search on here, I wrote some guidance a few weeks ago to the same question. here http://www.vectra-c.com/forum/showth...=rubber&page=2
    Oct 2007
    south wales
    Quote Originally Posted by Ste View Post
    Thanks Ste, I have a memory retention of a goldfish with a bad memory,
    You said "Remove top cover on engine (2 screws at the rear and the front slides off)
    remove the coil pack from on top of the plugs (just a few screws)"
    Are you talking about the metal bar or the big lump of plastic? thats where I am getting confused, as the bar is behind the plastic carbunkle, and has two hex screws holding that on?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The notes were for the standard 1.8, so yours may differ slightly, but the sentiment would be the same. I don't know what the bar is that you mention, mine didn't have it !
    Oct 2007
    south wales
    The metal bar is for the coil pack?
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. Request for a "How2" for changing colours in Photoshop?
    By Craig1985 in forum Photoshop section
    Last Post: 18th November 2010, 14:25
  3. "pulse" spark plugs
    By ballan22direct in forum Engine & Drivetrain
    Last Post: 31st July 2009, 20:58
  4. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  5. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
