Results 1 to 10 of 11
Thread: Fly-by-wire upgrade
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Fly-by-wire upgrade
    Was surfing and came across the site below and a link (sorry if its been posted before, 1st time I’ve seen it). Has anyone fitted one – does it make a difference.
    Did not think that this would/could be modified – do all vecs (models & pre/post facelift) come with the same standard of fly-by-wire system.
    The list seems to say it only cover Left Hand Drive models?
    http://www.mstuning.co.uk/pages/Sprint%20Booster.html
    http://news.windingroad.com/aftermar...print-booster/
    P.S. Pic of the A3 (top right) looks fab
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I am interested in this to, see what answer are given though
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Found this quote on internet
    Dick September 8th, 2007 9:00 PM Link
    I ran some tests with and without a Sprint Booster in my SLK. I wrote a technical white paper on the results. You can download it from bipesauto.com/sprintbooster.
    The Sprint Booster is a simple amplifier that multiplies the accelerator pedal sensor signal, making the accelerator pedal more sensitive. It does not eliminate any significant delay in throttle response, nor does it greatly improve acceleration figures. It does not change the adaptive throttle control programming of electronic throttle control vehicles. It does change pedal “feel”. This change in feel is interpreted by some as improved throttle response, acceleration, and a change in adaptive throttle control programming. Considering what it actually does, it is expensive.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    swatty it cover's all vectra
    BDD 251
    OPEL CORSA ALL
    BDD 251A*
    OPEL ASTRA ALL
    OPEL MERIVA ALL LHD MODELS
    OPEL VECTRA ALL
    OPEL AGILA ALL
    OPEL TIGRA ALL ALL PETROL
    OPEL ZAFIRA ALL & DIESEL
    does seem a tad expensive for what it does mind, if it were half the price then imo it would poss be worth a look at
    Midlands Mod Shop - NFFC.
    Jul 2006
    greenock
    Quote Originally Posted by ditchp View Post
    BDD 251
    OPEL CORSA ALL
    BDD 251A*
    OPEL ASTRA ALL
    OPEL VECTRA ALL
    OPEL AGILA ALL
    Hi Ditchp,
    It was the only word that made me think that the comment applied to the vec.
    Jul 2006
    greenock
    Quote Originally Posted by merikiito View Post
    Ah well merikiito, sound like it could be too good to be true (still interested to know if all vecs have the same throttle response as standard if anyone knows)
    It's snakeoil swatty..another 'tuning' gimmick..
    there is no way a device fitted to the throttle pedal potentiometer can make the intake servo motor open quicker for the same given voltage..
    I'd be keeping my money on that one..and saving it for better exhaust headers..
    Jul 2006
    greenock
    If it sounds too good to be true it probably is
    Oct 2006
    Wellingborough
    just push the pedal a bit harder, thats all this device does.
    Chester
    Sounds similar to the sports mode on the missus Astra. The engine revs higher with lower pressure on the accelerator. Doesn't go any quicker though.
  1. What wire do I cut lol
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2012, 09:01
  2. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  3. Which Wire ?
    By Ste in forum The 'Off Topic' room
    Last Post: 9th September 2012, 22:24
  4. Is this an ABS Wire?
    By asgharuk in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 19:32
  5. can you wire in an amp into....
    By jamesy in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2007, 18:23
