Thread: Slipping clutch or Flat spot or TC??
    Regular Member Stu14t's Avatar
    Perth, Scotland
    Default Slipping clutch or Flat spot or TC??
    Was driving to work on Friday morning and just pulled off the motorway onto the next section of motorway before I git to work. I decided, as no one was about, to give it a bit of right foot. Now this section of motorway is uphill and I noticed, as I was going up to third, a change in engine note. I glanced down at the rev counter and saw, even though foot was to the floor, the revs actually dropped back for a second from about 3k to just above 2.5k , then back up again.
    This has got me thinking a bit and would appreciate peoples thoughts.
    Is the clutch slipping or Is there a flat spot or was the traction control cutting the revs back? (road was dry)
    Mileage : 000
    I don,t know for sure what the problem was. But the clutch does not sound like it id slipping and the TC would not be working under those conditions I don,t think. I hope this was some help in eliminating the cause.
    Perth, Scotland
    Thanks Ed,
    I may send my map to BSR and see if they can tweak it.
    Trouble is it may be unique to my car.
    I see what you are saying about the clutch. At what point does the peek torque come in on the BSR maps? I know they drop it back deliberately at lower revs. Anyone put one on a RR yet?
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Quote Originally Posted by Stu14t View Post
    Someone I know who has a CDTI 150 too said to me they noticed a flat spot on these too. Dont know where he meant in the revs, but I recall him saying approx 3k rpm, but he said he consdiered chipping it. Dont know if its the same issue. Maybe same thing?
    if the clutch was slipping the revs would rise not fall, as the engines torque overcame the drag of the car/hill/gearbox.. so if they dipped you can safely say it's not the clutch 100%..
    i favour a momentary 'blip' in the cars ECU.. sort of a brain fart moment if you like.... TC wouldn't cut in on a dry road, not even in a diesel .. ( not an anti deisel comment, i did used to own a CDTi ) so it's more a management issue.. is it the BSR?, I don't think so..a faultcode session would prob reveal a momentary sensor fault that held the RPM back
    Perth, Scotland
    Tried it again this morning but didn't give it so much boot. There is a distinct flat spot at about 3k.
    When I did it today there was a distinct pause before the revs picked up.
    She is in for a service in about 2k miles, I'll mention it to them then to see if anything shows up.
  1. New Clutch Slipping
    By Anth92 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2012, 02:56
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Slipping clutch..
    By Steven in forum Engine & Drivetrain
    Last Post: 20th July 2011, 09:00
  4. slipping clutch
    By peadar in forum Engine & Drivetrain
    Last Post: 19th April 2009, 11:34
  5. Slipping Clutch
    By kel123 in forum Engine & Drivetrain
    Last Post: 12th July 2008, 11:16
