Results 1 to 10 of 13
Thread: Fog Lights
    Regular Member @ndy-e's Avatar
    Warrington
    Question Fog Lights
    One of my fogs is always full of condensation, it doesn't appear to be cracked anywhere so could a seal of gone and be a simple repair or would I have to buy a new fog?
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    i bet it is the passenger side
    your top up tank for your windscreen washers is right behind the passenger fog light and when you fill it up and you spill water behind it causes the fog light to mist up,there are quite a few on here it has happened to including me
    Here, there and every where!
    Regular Member simac's Avatar
    Wirral
    A quick fix is to remove the circular access cover from beneath the light and let the water out. Leave it off for a few days while it dries out, I drilled a tiny hole in the centre of the access cover before refitting it. Now any water drips straight out and it hasn't misted up since
    Also, there is a new "snorkel" mod which can be fitted too so you have a couple of options for fixing it.
    Warrington
    Yeah it is the passenger side
    Will it still be the same cause though as it does dry out later in the day?
    Wirral
    Yeah it will be the same problem, it will be drying out because you only have a small amount of water in there. The VX test is 20mins with the fog lights on, if it doesn't clear in that time they may change it under warranty. Although now this snorkel mod is out they probably just fit that.
    Warrington
    Whats the mod you mention?
    And does the cap just screw off?
    Wirral
    The snorkel is mentioned in this post:
    http://forum.vectra-c.com/showthread...hlight=snorkel
    The round cap under the light just twists off, when I took mine off about 1/2 a pint of water fell out lol
    You could leave the cap off but I found it annoying that if you use the lights you have a dot of light on the road, under the light fitting !
    or you could do what i have done....
    you know those tiny packets of silica gel you get with new trainers or in electrical goods... there's one of those in all my lights.... no condensation in my foglights as the silica gel absorbs the moisture..
    Warrington
    Thanks simac, will try it tonight.
    Can you fit the gels easy enough without taking the fog light off?
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
