Thread: Quick question. Need help
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Quick question. Need help
    I understand that my indicator clicker thingy and the alarm noise when you lights are left on, are not working due to the cim.
    Can anyone confirm and also is the link below a cim that will fit my car. 2.2 dti sri?
    Link
    Dan
    Here, there and every where!
    Probably not m8 as it is from a 2006 full CANBUS car and yours will be half CANBUS.
    Jul 2006
    Northampton
    Trim : Sri
    maybe next time
    Regular Member djr69uk's Avatar
    Midlands
    do these things need to be tech2'd or anything? someone suggested that the reason my rear wiper doesn't work might be because of the CIM module...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes it does need tech2.. (have had mine changed, due to indicator fault).
    But dont understand mugualigwian.. is it broken? (so those 2 things dont work anymore). if never worked, probaly tech2 thing...
    it's just the tiny speaker unit that has failed.. hence no noise being produced..
    the CIM does need quite a bit of setting up , either via tech2 or now via Vaux-com, so it's far from plug n play
    south wales
    my cruise control works but trying to get it to pull away on button is a nightmare,you have to push top button the light will flick on then off then press the bottom memory button and it will stick on,when i cleaned the inside with a steamer it work fine for a bit is this that cim or the stalk which i know you can't buy seperate
    it could be just the stalk.. which is a seperate part.. they just clip into the CIM module...
    south wales
    just found this,if he needs the cim i need a stalk
    http://cgi.ebay.co.uk/Vauxhall-Vectr...2em118Q2el1247
    it's cheap.. but it will rely on what Ident code Mugualigwian's exisiting unit has on it...he needs to get an identical replacement unit..
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
