Thread: how do i change the glow plugs
    Regular Member tim wood's Avatar
    Apr 2008
    peterborough
    Default how do i change the glow plugs
    i think i need to change the glow plugs on my 2.2dti does anybody have any advice on where they are and how easy they are to change etc? thanks
    Hertfordshire
    Fairly easy job to do, but do be aware that this engine in the Vec B has been known to have glow plugs snap off in the head when people try to change them.
    Just be aware of this before you go jumping in and change them yourself.
    If you are not confident you can cope with changing them then get someone who is to do it for you.
    If you snap one, you MAY end up having to take the head off, and possibly have a helicoil fitted if the thread in the head is damaged taking the remains of the old plug out.
    Don’t let me scare you and put you off, it is really just pot luck weather they come straight out or are really tight.
    You’ll find them on the rear side of the engine, with leads attached to them and will look very similar to a spark plug and lead.
    The leads are clipped on, squeeze them in the right place to release them, do not force them or you’ll break the lead.
    You’ll need to take the black plastic cover off the top of the engine to get to them all.
    And you may find taking the top boost hose off will give you more room as well.
    Make sure the socket is on the plug square, not at angle or you’ll increase the risk of snapping them.
    Don’t jerk the ratchet, be smooth and using even force to undo them.
    You MUST use a torque wrench to do them up, do NOT over tighten them. (or they will be more likely to snap next time)
    Also, use some copper grease on the threads before you fit them.
    Apr 2008
    peterborough
    you say on vec b is this the same for mine as mine is a vectra c? do you have to torque them up as i have always just tightned just a bit tighter than hand tight with a ratchet?
    Regular Member TKD Colin's Avatar
    Jan 2008
    london
    definately be cautious with removing glow plugs........
    my car is in the garage right now with the head off because of two snapped glow plugs
    I miss my baby she has been gone for three days already.
    Hertfordshire
    Yep, basically the same engine, minor differences, but in terms of glow plugs identical, and they have a track record of seizing.
    The older the car, and the higher the mileage the more likely this is, and of course if they were over tightened when fitted.
    Yes, it is VERY advisable to torque them of correctly, not just by feel, I can't remember the figure off the top of my head, but when I changed mine the new plugs had the setting written on the box. (NGK plugs not Vx ones, though I don’t know who makes em for Vx)
    Apr 2008
    peterborough
    okay is it best to give them a squirt with wd40 and leave it for half an hour before removing them. what glow plugs would you advise? thanks
    Hertfordshire
    Yes, sorry I forgot that tip, won’t do any harm at all to give them a good soak with the WD before you try to undo them.
    Just price up plugs local to you, try Vx and try a local motor factors, and get whichever is cheaper, I would stick to a known name to plugs though, rather than a cheap eBay set, my local motor factors supply NGK (very good quality plug) but yours may be different. Any known quality brand is fine, NGK, Champion, Bosch, ETC.
    Apr 2008
    peterborough
    okay no prob thanks for you help i mite atempt it tommorrow.
  1. how to change glow plugs on 1.9cdti
    By mr.4dil in forum Diesel Engine related
    Last Post: 11th May 2011, 20:01
  2. Glow plugs change
    By deeks in forum Diesel Engine related
    Last Post: 21st April 2011, 15:47
  3. 1.9 cdti 150/ How often should you change the glow plugs?
    By richiem in forum Engine & Drivetrain
    Last Post: 14th January 2011, 15:16
  4. change glow plugs
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2010, 17:42
  5. Change Glow Plugs on 120 CDTI
    By RS_Turbo in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2009, 09:28
