Thread: how much will my car be lowered?
    Regular Member tim wood's Avatar
    Apr 2008
    peterborough
    Default how much will my car be lowered?
    I am looking into buying some jamex 35mm springs. i have a 53 reg sri dti so how much will my car be lowered by when i have fitted the springs? Are they easy to fit on theys vectras? thanks
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    as the sris are 15mm lower than the standard vectra it will lower it by about 20mm
    are they easy to fit?.. no harder than other cars.. in fact the rears are a 15 minute doddle if you have the right tools..
    Apr 2008
    peterborough
    will that look alrite on the standard sri wheels? i am looking at some 18s at the mo. it just looks like a bit of a 4x4 at the mo.
    it will sit nicely on the 18's at -35mm overall..
    Apr 2008
    peterborough
    cool so cant go wrong for 80 quid including delivery hopefully there not to harder springs and will be alrite on standard shocks.
    they will be a harder ride, and a lot stiffer than the standard SRi setup..the shocks will be okay for a while, but may start to bottom out if you really load the car up..really -30mm is the max on SRi dampers.. for -45 springs ( from standard ride height) you'd be better off looking at shorter shocks
    Apr 2008
    peterborough
    okay thanks alot for your help.
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Sound advice as usuall Mark
    CXan you recommend some shorter shocks?? Bilstein B4's perhaps????
    use the shorter one's in the bilstein range.. B6's i believe iirc
  1. another lowered C !
    By bembo449 in forum Engine & Drivetrain
    Last Post: 24th June 2011, 22:15
  2. Lowered car but .............
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2011, 21:04
  3. Lowered...
    By P3tchy in forum Styling
    Last Post: 15th March 2010, 12:35
  4. Lowered!!!! :-)
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 14:32
  5. car lowered
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 14:48
