Results 1 to 10 of 11
Thread: CDC40 Opera Radio - CD Problem
    May 2008
    Newcastle
    Default CDC40 Opera Radio - CD Problem
    Hello everyone, I'm new to this so please bear with me. I am having difficulty loading a CD into my CDC40. It feels like there is something inside stopping it from loading but there are no discs loaded. Is there a trick to loading? The Handbook says refer to "inserting CD" but this topic doesn't appear in my handbook on page 29!
    Regular Member Matty H's Avatar
    Bristol
    You have to select CD then select an empty slot ie - 1,2,3,4,5 or 6, then press the big center button button and it will say "insert CD" or something like that. Then the CD will slide in no problem
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    When you press the botton you have to wait until it actually tells you to insert cd.Try before hand and it feels like you said.hope this helps
    Nov 2007
    Sweden
    Couldnīt have described it better.
    Itīs a little bit tricky and you tend to forget how to do it each time.
    Great to have a 6-disc changer with MP3
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Quote Originally Posted by Matty H View Post
    after selecting CD you then have to press the eject button, then select empty slot as above.
    May 2008
    Newcastle
    Thanks Matty. Got it going and sounds great.
    May 2008
    Newcastle
    Thumbs up CDC40 Opera Radio - CD ...NO MORE PROBLEMS
    All is well now. Thanks everyone. By the way "m-duck" where is the MP3 player plug? Maybe it isn't on the 2005 model?
    Bristol
    Quote Originally Posted by ClaraCDXi View Post
    No probs. Glad you got it sorted. It's a cracking system. I couldn't go back to a non DAB Car Stereo now
    Chester
    Matt, can you confirm that your radio will play Mp3 discs?
    Cheers.
    Bristol
    Hi Steve.
    I assume you meam MP3 files copied to CD? If so, yes it does mate
  1. Cdc40 opera
    By paulcdti150 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2011, 16:26
  2. CDC40 Opera
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2010, 12:43
  3. CDC40 DAB Radio problem
    By Avenged in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2009, 22:48
  4. CDC40 Opera AM Radio Reception
    By willc01 in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2007, 17:19
  5. CDC40 Opera with Dab
    By greeningr in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2006, 22:48
cdc 40 opera faults
cdc40 opera opel nu apare insert cd forum
probleme cdc40 opel
vectra cdc 40 opera cd insertion
vauxhall vectra c no cd problem
how to put code in cdc40 opera radio
cdc40 opera cd error
cdc40 cd error
opel radio cdc40 opera mp3
