Results 1 to 10 of 13
Thread: Where to get a new filler cap?
    Regular Member Lloydy's Avatar
    Newbury
    Default Where to get a new filler cap?
    Yes, you guessed, I drove off with the petrol filler cap still sitting on the roof, and I've no idea where it ended up. Can't find it anywhere!
    So, what's the best solution for a replacement? Halfords?
    Actually it seems fine without a cap, but I guess its dangerous in the event of accidents & fume leakage.
    Nr Cardiff
    If it's a diesel you drive it's also bl88dy dangerous for motorcyclists as well, dumped diesel on corners is a deathtrap. Get it replaced ASAP.
    Try LMF, they should have them . The filler neck now has a flap in it to prevent the fuel splashing out so it isn`t as bad as it used to be with no cap ...
    I know what you mean about diesel though, roundabouts are the worst !!!
    Quote Originally Posted by Lloydy
    I can't imagine them being that much from Vx bud. Have you had a price from them yet?
    Regular Member MLC's Avatar
    uk
    Some replacement caps are junk, get a Vx one! Don't you use the little holder on the flap?
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    You shouldn't need to put it on your roof whilst filling the tank. If you look inside your fuel flap, there's a little clip thingie to hold the filler cap whilst you're fueling.
    You can't shut the flap with the cap on the clip....so it's impossible to forget to replace it.
    A classic "RTH error"
    (smug) Doug
    Kent, UK
    That's what I was thinking! VX kindly provide a holder for this exact reason!
    Newbury
    Quote Originally Posted by MLC
    Little holder on the flap? Didn't know there was one! I'll look for that when I go home tonight.
    By the way, its a petrol car and there was no leakage, even when the tank was full. For now I've got a temp cap but I'll get a Vx one ASAP.
    Newbury
    Got a new cap from Vx this afternoon. £9.99 inc VAT.
    Also found the clip on the filler flap, and hey, what a good idea! Wondered what that was for!
    Mileage : 55000
    By the cap holder there should be a gray thing. that is to enable you to get the tyre valve cap off, has anyone noticed that too.
  1. Best Oil to use and where does it go(apart from the oil filler)
    By caravaner-tony in forum Engine & Drivetrain
    Last Post: 30th August 2010, 21:23
  2. Oil Filler Cap
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 12th July 2008, 12:53
  3. Filler
    By Ste in forum General Chat
    Last Post: 3rd February 2008, 21:11
  4. how much is a filler cap?
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 22:14
  5. Filler Cap
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2005, 08:07
