Thread: injectors vectra di
    May 2008
    heywood lancashire
    Default injectors vectra di
    are the injectors in a vectra di the same as the dti
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Got any engine codes for these both 2.0 diesels i take it? Need to know the engine code ie X20DTL or X20DTH or Y20DTH to be able to give further info.. some share injectors but dependant on their emission coding and also a chassis number would be helpful too, the X20DTL injectors change on 17062265 chassis number
    May 2008
    heywood lancashire
    Quote Originally Posted by plasma View Post
    mine i
    May 2008
    heywood lancashire
    Hi
    engine num 17437780
    vinwolojbf69x7074036
    injector are on ebay item num 180242021985
    and engine code is a dtl mine
    Thanks any help would be great Ian nic one
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    would this be a vec B engine
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    yes steve di was an older diesel enginer without intercooler producing about 70bhp the dti had an intercooler and produced about 90-100bhp..
    Will look into the injectors and see whats what
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    On the low pressure turbos they did 2 injectors one with part number 90543761 and emission code NC8 and the other 9192712 with emission code NT5..
    So a) you'd need to know exactly which type because it doesnt differentiate with the parts guide i have and b) you'd need to know which ones the seller has on ebay too.. sorry couldnt give you just a yes or no answer like you wanted buy didnt want to say yes and you buy incompatible injectors..
    Best bet is to ask the dealer which type you would have they should be able to look this up with your reg no or vin no and then ask the seller if they have an emission code on the plugs.. the part number he has doesnt match with mine but probably the dealer has access to this other code.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Is there any larger injectors compatable for the 2.2 dti? i fancy spending a bit more on fuel! Would larger injectors make much of a difference on a diesel?
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    the diesel flow it set by the ecu normally, so even if you did find a set of compatible injectors although i'd say there isnt. 2.2diesel is as big as they get without changing manufacturers (ie like for the 3ltr lump) bigger injectors would only be required like on a petrol if you up the flow and reach the maximum flow rate the injector allows. so for you mate, the answer is NO
    Jul 2006
    Northampton
    Trim : Sri
    Ok cheers, was just a thought after reading this lol
  1. injectors
    By sandy13 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st January 2012, 11:08
  2. Injectors
    By signumboy in forum Engine & Drivetrain
    Last Post: 28th September 2011, 21:23
  3. Injectors
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 10:49
  4. vectra 2.0T upgrade injectors
    By jay666 in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 19:55
  5. Injectors? help
    By Ean in forum The 'Off Topic' room
    Last Post: 26th October 2009, 12:56
2.2 dti larger injectors
