Thread: HID conversion kit
    Regular Member Wolf's Avatar
    London
    Default HID conversion kit
    I just bought a HID kit and I was wondering how hard is it to fit? I just want to know if it's worth trying or shoud I go to a specialist.
    Sunny Dartmoor
    Apparently very easy,not done it myself but give it a go........
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I fitted the HIDS4U kit & it was plug & play - the hardest part was getting the bulb retaining clip to fit properly. The first one took about 30 minutes of bending, twisting & cursing before I got it to hold the bulb in but the second took about 30 seconds as I knew what to do by then. The only other problem was where to stick the control boxes as room is at a premium, but the job itself is fidldy but simple.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Space is tight on the drivers side,i found the best places to mount the ballast is under the headlight on the crash can or bolt it onto the slam panel,depends on the size and length of the loom.
    Full Member Big Sig's Avatar
    Make sure you got the right type thats compatible with the veccy's self bulb check system. There is a how too on here I think
    London
    Thanks gents. Will probably give it a go this weekend If the weather is OK
    Scotland
    do the HIDs pass MOTs ok?
    Yes normally. Although technically they are a failure due to the fact they have no self levelling or washers.
    London
    I just passed my MOT last weekend so not really worried about it.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Very easy to fit them, i have recently fitted HIDs. I mounted the ballast down the side by the light, there is a nice little shelf there for it to sit on.
  1. Vec C 2.0T LPG Conversion
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2012, 10:13
  2. LED conversion
    By nicj in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2011, 00:51
  3. Led Conversion
    By JonesG in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 20:21
  4. HID conversion
    By spooney in forum Styling
    Last Post: 20th January 2009, 20:20
  5. vxr conversion
    By c9rum in forum Petrol Engine related
    Last Post: 10th January 2009, 20:49
hid conversion 2008 vectra
