Results 1 to 10 of 15
Thread: Tech 2 for towing electrics
    Oct 2007
    Reading
    Vehicle : SAAB
    Trim : LINEAR SE
    Default Tech 2 for towing electrics
    I've just fitted a Bosal tow bar and VX electrics (12N and 12S) to my full canbus estate. But none of the electrics are working apart from the 12V supply to the charge relay, so I assume they need to be enabled by Tech 2 as suggested in the instructions and reading posts on here.
    Phoned four local VX dealers:
    1. 0.8h labour £62.50
    2. 1h labour £96.35
    3. Gave up waiting on hold, which is unfortunate as they are the most local
    4. 0.5h labour £36.00
    Does any of these seem reasonable?
    Seens a lot of money just to reprogramme the car. I have booked the last one for next Monday as they are the cheapest.
    Sunny Dartmoor
    Thought you didn't have to have towbars tech2'd,there's a thread about it somewhere,hang on........
    Here you go,it does state "may not need Tech2'ing",have read through it mate......
    http://www.vectra-c.com/forum/showth...hlight=towbars
    Oct 2007
    Reading
    Vehicle : SAAB
    Trim : LINEAR SE
    Thanks, already read through it and a few others on here. Disconnected the battery as the leaflet says, fitted the electrics, reconnected the battery, nothing working (as above), tried disconnecting the battery for about 30mins same, so it looks as if my car is one of those which does needs Tech 2'ing.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Inner Zone View Post
    2. 1h labour £96.35
    Well the first two are completely outrageous prices - both on cost and the amount of time they are implying it will take. The fourth is getting more reasonable - given that the actual job takes about 10 minutes!
    Full Member Big Sig's Avatar
    I'd go with number 4. Mose dealers charge a min of half hour labour near me.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    it does need tech2 .
    then bulpfaliur also work on trailer plus you have a xtra warning when turning, and som other features.
    Regular Member scottyd's Avatar
    paisley
    any how 2 for this
    to do what? enable the towing electrics?..
    Thats tech2 or vauxcom only really... 'most' cars auto detect the prescence of the module.. it seems this one needs a little help..
    if it's a wiring 'how-2' then all the instructions ( and the tech2 menu instructions) come with the genuine VX wiring kits..
    Regular Member 30ltr nutter's Avatar
    dunstable
    i had to have mine tech2d as they dont switch the power supply on at the factory i think it cost half hour labour
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    my Elite needed Tech when the 12n &12s sockets were put on
  1. Towing electrics
    By iain.condliffe in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 20:26
  2. Towing electrics without the v/x kit
    By crgv6 in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2010, 18:40
  3. towing electrics and op com
    By winnie2457 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2010, 12:13
  4. Towing electrics kit
    By ally1873 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2007, 23:35
