Thread: Topping up engine oil... engine warm or cold?
    Northants
    Engine : 1.9TDCI [150]
    Default Topping up engine oil... engine warm or cold?
    Checked the oil level on my Signum yesterday and it was a little low, so I'm planning a trip to the dealers later to get myself a liter of oil. I've never had to top up a car with oil before, so excuse me if I ask a stupid question...
    Do you top up when the engine is warm (mentioned in the owners manual is that you should check the level about 5 minutes after the engine has been run at operating temperature) or when the engine is stone cold? My gut feeling says the former, but I rather confirm it here before I mess it up
    Ta!
    Q.
    Sunny Dartmoor
    I have always checked and topped up, with the engine cold.....
    cambs
    hi
    always do it cold m8
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    i have done it when its cold.. to just below the max everytime. never had a problem to date.
    i always check them cold or if the engine is warm, at least 5 mins after the engine has run to allow the oil to drain back into the sump to give the correct reading....doing it too quick will give you a false lower reading..
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    on the topic of topping up oil, what is the norm for a 1.9 CDTi using oil.
    Ive done 4,123 miles since my service should it need a top up?
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    According to the manual on my 2.0 Turbo the oil should always be checked when warm.
    I too had always checked it when cold too.
    our old 150 never used a drop..
    to be fair..most engines these days hardly use a thing...but you do need to check it more often than every 4,000 miles....try at least once a month..
  1. Warm air from engine when its cold
    By Mikey4996 in forum Engine & Drivetrain
    Last Post: 30th November 2011, 20:23
  2. How long for the engine to warm up?
    Last Post: 6th January 2011, 18:03
  3. 2.2 direct engine starts cold but doesn't warm?
    By barnesy in forum Engine & Drivetrain
    Last Post: 19th December 2010, 12:09
  4. 2.2 Direct warm engine start
    By Sambor in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:12
  5. Stuttering engine when engine is cold
    By chris_sri in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 00:25
topping up engine oil vauxhall vectra
