Thread: Steering Wheel Controls, Help!
    norfolk
    Default Steering Wheel Controls, Help!
    Hi All, I Have Just Found Out My Steering Controls Dont Work On My 2002 1.8ls, Does Anyone Know Where I Should Look First I.e Fuse,wire Etc, Also My Horn Isn't Working, I Have The 3 Buttons On Each Side Of The Steering Wheel, And The Head Unit Is Cdr500, Cheers..
    Sunny Dartmoor
    Would check fuses first mate.....
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Horn fuse is F5 in the engine bay fuse block, should be 15A. Same if you have one or two horns. Earth wire for both is brown, power wire is red with a brown tracer. The only item I could locate in regards the radio controls were an item called "Steering Column Control Unit" which is supplied by F10 at 7.5A in the passengers fuse block(L/H end of dash). Worth a look, good luck.
    Full Member Big Sig's Avatar
    Isn't the only thing that links all those the CIM?
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. steering wheel controls.
    By Vectra boy in forum Electrical & ICE (including SatNav)
    Last Post: 21st August 2012, 15:20
  3. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
  4. Steering wheel controls...
    By vauxhall4life in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2008, 22:46
