Results 1 to 10 of 17
Thread: I know stealers were bad ...
    Regular Member Rob_the_Scot's Avatar
    London
    Eek I know stealers were bad ...
    Not being good at how things work under the bonnet..
    Car needs serviced, call the local dealer –
    Quote:
    Service – £246.77 inc VAT
    Requires to check service history for:
    Brake fluid - £49.35 (requires every 2 years)
    Coolant - £56.00 (requires every 2 years)
    Ouch, oh well, has to be done
    Full Member Big Sig's Avatar
    Go to an indie garage, vat reg'd, keep the schedule and save a few beer tokens
    The best bit is, it won't effect your warranty!
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Is it essential the brake fluid is changed or is it just the dealers saying it needs to be done?
    London
    Brake fluid needs done. Will take Big Sig advice and phone round a few indie garages, there are loads in east London
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If you want to cross the water i can recommend in Erith.
    Regular Member shan's Avatar
    Is this for a second "major" service ?
    I had mine done at midpoint in Cheshire and they charged me 150 including VAT. I know it's 250ish miles away from you but maybe you are up this way sometime soon.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I thought that coolant requires changing every 4 years.
    And I'm pretty sure my local dealer does a brake fluid change for around £25.
    Worth ringing around and getting a few quotes.
    south wales
    new bumper from vauxhall with no trim no fogs or grills £255,same bumper on ebay all primed like vauxhall £120,light on ebay tinted £56 vauxhall £115,little fog light from vauxhall £60
    Nicking Ya Dinner.
    Save some money, drain the bottom rad hose and pre-mix some new anti freeze, fill it back up and run the air out of it, brake fluid I find is a con, it's a cover yer back issue tbh, if it's clean it should be ok, if there's any water in it you will feel it at the pedal.
    Just looked Rob, yours is a 2002 model, scrub the service, I used to service mine myself for £50 using all GM stuff on the trade card, this was...
    1 - 5 litres of 10/40
    2 - Oil Filter
    3 - Oil Flush
    4 - Oil Reconditioner
    5 - Diesel Filter
    6 - Pollen Filter
    7 - Air Filter
    8 - Fuel Treatment
    9 - Sump plug Ring
    Now look at what they will do for 5x
    Service history is not important at the cars age, I reckon if you ask the right person here to get the bits you can do the lot for £60 and have £290 in your pocket.
    Admin plasma's Avatar
    On the Forum
    180 Post(s)
    Engine : 150
    Mileage : 74000
    Rob, if ya want, i can help you do a service, not a big job at all, brakes will be no problem too. Coolant you just need to check you have the right amount of antifreeze mixture in it then job done.. Lemme know mate, we could do it one weekend.
  1. just been to the stealers...
    By Vectra boy in forum General Chat
    Last Post: 19th September 2011, 20:11
  2. Sat in the stealers
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2011, 18:47
  3. Car is in the stealers....
    By Matt&Jemz in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 12:44
  4. Stealers little ********
    By Largespanners in forum Suspension, Wheels & Brakes
    Last Post: 14th August 2009, 01:08
  5. My car is in the stealers
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 21:39
