Results 1 to 10 of 15
Thread: Aaarrrgh !!!!
    scotland
    Default Aaarrrgh !!!!
    hi peeps , the story is I had an oil leak from my N/S driveshaft ( 1.8 ) so I changed the driveshaft oil seal and thought that was it ..... WRONG still leaked .
    I then tried another driveshaft ( just incase first one was worn or something ) and a new seal again . and now you've guessed it STILL F###'N LEAKING !
    My question to you is WTF is wrong here ? is there another seal further into gearbox ? does the box need stripped for this ?
    or what else can be the prob?
    thanks gurus
    Regular Member djr69uk's Avatar
    Midlands
    not familiar with the f40 but my bird's puma had a gearbox leak recently and it was an internal gearbox seal. apparently there are something like 3 seals in the box. she took it to an independant gearbox specialist and they only charged £150 to sort it. so worth shopping around if it is that mate.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Most likely its the rear main oil seal (I've had two!) - is the leak dripping down roughly in line with the sump plug and then running down the arm?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by JuzzyD View Post
    Had the same one done as well, then they found a leak from the sump gasket. All fixed under warranty.
    scotland
    the leak is from the driveshaft seal as far as I can see , all other gaskets etc are fine thats why I ask if its further inside g/box.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Do these help?
    scotland
    its not the shaft thats complete and dry all clips secure , the other pic I cant relate to but like I said before the oil is comin out the g/box and past the outer seal even when the driveshaft has been replaced .
    scotland
    anyone else ????
    checked the breather on the top of the box is clear so it's no pressurising the casing and forcing oil out?
    scotland
    not this its as clean as a whistle .
    any parts fiche or diagrams online I could explore ??
vectra c driveshaft oil seal replacement www.vectra-c.com
