Thread: Revs to 3k immediately after starting
    May 2008
    Australia
    Default Revs to 3k immediately after starting
    I have 2003 C Vectra 2.2 eco.
    Immediately after starting she revs to 3k and just sits there.
    Does not respond to throttle at all. i.e. pushing the throttle does not make her rev more.
    I drove it home one night and it was fine then the next morning when I started her, she was doing this!
    Anyone have any ideas? The engine light stays on.
    Full Member Big Sig's Avatar
    Hmmm, Maybe the electronic pedal box. There isn't a throttle cable on that I don't think so it could be the ecu not getting a signal for the throttle position from the pedal box. Someone else may have a better idea????
    HTH
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Quote Originally Posted by Senator View Post
    Hi mate,
    if the light is staying on then I would get the trouble code read as this would pinpoint the cause of the problem.
    May 2008
    Australia
    How do you read the code from the 2.2?
    I have seen the thread for the 3.2V6. Is it the same for the 2.2 4 cylinder?
    Nov 2007
    Bournemouth
    Either take it to a garage to get them to read the codes, or buy something like this to do it yourself
    http://cgi.ebay.co.uk/U381-LIVE-DATA...QQcmdZViewItem
    yep, you need a CAN compatible OBDII code reader .... thats the best way to find out what ails it..
    Feb 2007
    Glasgow
    Quote Originally Posted by Gavin1977 View Post
    Don't get the U381, it doesn't do CAN, you need the U581...
    http://cgi.ebay.co.uk/U581-Car-Diagn...QQcmdZViewItem
    May 2008
    Australia
    I took it to my local garage, but he couldn't read the codes from it for some reason (maybe the CAN / ODB you mentioned).
    It's @ the dealer now. All I can hear is $$$$$$$.
    I think it is actually in that limp mode, or some variant of it. I drove it to the local garage and it drove OK. Just sat on 3k rpm, I put it in neutral at the traffic lights. Otherwise would just get upto 50km/hour and sorta stop there.
    I'll post up whatever the problem ends up being, but whatever it is I'm sure its going to be expensive
    May 2008
    Australia
    MAP Sensor.
    He said $40->$50 AUD for the sensor 1.5 hrs labour. $1AUD -> 50 pence about.
    Not too bad !
    not too bad at all... quite reasonable really..
  1. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  2. 1.8 revs stuck after starting, EM on!
    By GizmoGary in forum Engine & Drivetrain
    Last Post: 9th May 2012, 15:42
  3. Intermitant Problems Starting - Revs limited to 2K
    By Beridor in forum Engine & Drivetrain
    Last Post: 6th July 2010, 16:30
  4. 2.0 dti cutting out immediately after starting
    By Boz657 in forum Engine & Drivetrain
    Last Post: 13th December 2009, 00:55
  5. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
