Thread: petrol gauge
    Regular Member pitsmoor21's Avatar
    Apr 2008
    sheffield
    Default petrol gauge
    Hi does anyone know how many ltrs each section of the gauge represents
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The tank is 60 litres, so if the gauge it truly linear, you can then just divide the necessary sections into it.
    I would doubt that the gauge is perfectly linear tbh. Maybe a little experiment is necessary? Next time you fill up from empty, stop at each section marker and check how much fuel you have dispensed into the tank = question fully answered.
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    I would say there are too many factors to count for giving a reliable figure. Personally I fill the tank, re-set the trip indicator and when the low fuel indicator warning light statrs to flash I know I've roughly 5 miles left. I've worked out my 1.8 does 410 miles to the tank on average.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Ste View Post
    I would say the same i.e. the gauge is not linear based on seeing how it drops in cars I've had - including the Signum.
    Even that is unlikely to be of use due to the delay from putting in the fuel to it registering on the gauge as it's not instantaneous - so difficult to get it to settle on the section marker, unless you stand for ages filling it up a bit at a time! lol
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, it would take a bit of time, but would absolutely answer the question.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    They never seem to be very accurate at all, over the whole tank. I know on my vec, I can do 110+ miles before the needle goes past the first segment (an 1/8th of the gauge). I get 600 miles per tank, not 110x8 = 880!
    Generally, it seems to go down a bit quicker after it passes half empty. Beats me why nobody can make a 100% accurate fuel gauge yet
    Full Member Big Sig's Avatar
    Its all down to the shape of the tank is it not? Its not perfectly square ot anything, it has rounded corners and depending on the car the base may not be flat, its just not worth the development to get a gauge to reflect the tanks shape and the usage curve it would therefor represent on a linear scale....... I think!
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    Couldn you just make a habit of heading to a service station each time the needle hits one of the markers, fill it up to the neck , and keep track of the results? ( that is, if you have nothing better to do )
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Tank geometry isn't really the root cause here, it's about how the sender signal is used by the car to display fuel level.
    If it's a simple resistance meter, then yes the tank geometry will influence the accuracy. If the signal is processed in any way, then the system (sender and gauge) can be calibrated to take shape into account and accurately display fuel level at all times.
    It comes down to dev costs and whether the inaccuracies can be minimised / lived with.
  1. Petrol gauge help
    By peelmeister in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 08:06
  2. Petrol Gauge Playing Up
    By Baggers 2.0 in forum Engine & Drivetrain
    Last Post: 4th November 2011, 13:41
  3. Petrol gauge stuck
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 18:18
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Replies: 2
    Last Post: 15th September 2008, 23:18
