Results 1 to 3 of 3
Thread: 150 cdti oil leaks?
    London
    Default 150 cdti oil leaks?
    Any one else with a z19dth engine suffer from oil leaks or am I the lucky one?
    I have a leak at the front top right of the engine and also one at the top back right. They're both in the region of but far below the oil filler cap (definitely not coming from there).
    Asked the dealer to look at them while the car was in for servicing (and new swirl valves) but he reckoned "They're all like that, sir..." and "We've tightened everything up, sir...". Didn't clean the oil away though...
    Looks like it's misting from somewhere as it's never used a drop of oil in the time we've had it, so how far do I push the matter? Getting hacked off with the dealer but the trouble is it's only 1/2 mile away and part of a chain that has a monopoly in our area...
    it may just need new cam cover gaskets... got any photo's of the affected area's?..
    Regular Member foyboy241177's Avatar
    May 2008
    eastbourne
    it not cam cover gasket as dont leak cheak vacum pump gasket nsf of engine with plastic hose with yellow tags attached work in main dealer and done lots of them
  1. 3.2 GTS leaks coolant
    By rekordi in forum Engine & Drivetrain
    Last Post: 7th December 2011, 08:07
  2. 2.0 dti oil leaks
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 18:02
  3. Wiki Leaks
    By Aidi in forum The 'Off Topic' room
    Last Post: 29th November 2010, 19:40
  4. 150 CDTI Oil Leaks
    By andwat in forum Engine & Drivetrain
    Last Post: 21st February 2010, 22:01
  5. Water leaks in boot?
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 13:15
vectra cdti oil leak
