Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Help, Xbox Live
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Help, Xbox Live
    just tried to get online and fell at the first hurdle..
    1) my ethernet cable thingie is too big to go directly into the broadband modem..
    managed to overcome that as then it connects to my pc via a usb lead... which i have plugged into the back of the xbox but
    2) it wont recognise it...when i click to do the 'test connection' it keeps saying its disconected... how do i connect.. please help!!..
    (heres how the connection is currently set up..telephone line.. splitter(tel and sky) and filter..dsl cable to modem, then usb slot to pc..although the usb cable fits in the pc..at the back of the modem box is like a usb block..)
    currently using tiscali as my service provider, wired, with a sagem fast modem box...
    Full Member Big Sig's Avatar
    Have you tried resetting the modem with the pc and xbox turned off? I could never get that to work so I unplug the modem and swap the cables round each time!
    the xbox isnt connected through the pc...i basically have taken the usb from the back of the computer..and put it into the back of the 360..
    the usb port on the back isn't for the xbox modem. It needs to use a lan cable for that. If thats what you meant then
    Try turning the xbox off, reset the modem and wait for it to connect, then reboot the xbox. thats what I do.
    yep thats what i meant...where the usb connects into the back of the pc normally..i have just put it into the back of the 360... (via the modem etc)
    guess i cant do that then!!
    how am i gonna do this then... if the lan? cable wont fit in my modem?..
    the modem end will be fine, you need a usb too lan/ethernet cable. the xbox needs the telephone type cable end plugged in.
    i'm really stuck..the cable that came with the 360 physically wont fit in the back of my modem..cant get my head round it,,, the ethernet cable (i think)
    wont go into anythin..apart from the back of the 360..??..
    my dsl line from the filter wont go into the 360 as its too small...
    do i need a router then with 2 ports i guess..just got the destructions from upstairs..
    Thats really odd as all lan/ethernet cables use the same style end. you sure there isn't a sticker covering the port or anything?
    just been readin on line that the tiscali modems are usb modems..i need a cable modem i think..
  1. Is Xbox live down????
    By Damo77 in forum Games Room
    Last Post: 17th December 2011, 15:19
  2. xbox live
    By marc vectra sri in forum Games Room
    Last Post: 6th October 2011, 13:19
  3. Xbox live?? C.o.d 4??? Other live games.
    By baz_rochdale in forum Games Room
    Last Post: 21st October 2009, 20:28
  4. Anyone on xbox live now??
    By m3ath3ad in forum Games Room
    Last Post: 8th May 2009, 12:55
  5. xbox live
    By leeandjude in forum Games Room
    Last Post: 14th October 2007, 21:23
