Results 1 to 10 of 11
Thread: loss of power 150 cdti
    Regular Member SRI-150's Avatar
    Jun 2007
    Cheshire
    Default loss of power 150 cdti
    the cars going in to the dealers in the morning to see why i have no power, its like it'll pull for 1 second an then jus run without the turbo as in very slow, reved to about 4k in 3rd on the way to work an got spanner light on all the time not just at start up like it has been but after a restart that went, anyone got any ideas what it is???
    Ashington, Northumberland
    Quote Originally Posted by SRI-150 View Post
    That could be absolutely anything. There is no way of saying it's definately this or it's definately that from descriptions of faults. The only way to see what's going on is tech 2 (or other compatible code reader)
    Full Member Big Sig's Avatar
    Egr or Swirl valve! (imo)
    Egr or Swirl valve!
    How do you arrive at that diagnosis then? Yea could well be one of those items (we all know the trouble these two items cause on Vecs), could also be a turbo fault, could be something rattling in the engine which the knock sensor is picking up and retarding the ignition or even a faulty knock sensor or even loose(torque setting is critical for a knock sensor), could be a faulty MAF sensor, could be a faulty throttle pedal position sensor (Either one), could be a faulty temp sensor etc etc etc. lol. Anyway, you may well be right in your diagnosis , lets see what his tech 2 throws up.
    EDIT: PMSL just seen your edit
    Jun 2007
    Cheshire
    could well be anything hopefully not to bad that they have to have it for too long i'll let u's know what it is when i get told
    Jun 2007
    Cheshire
    well got it back that night to find it exactly the same so told the manager to come with me in it, showed him an he sed ohh yer it should be a lot quicker. let me have a go so he did, went round the block in 1st gear it clears the exhaust, i was like get ur foot off the accelerator its not the exhaust and it doesn't need cleaning out by redlining it constatly. went back tech 2 came up with same problem, boost pressure valve which they had supposedly cleaned out, so we were looking under the bonnet wen he spotted vacuum pipe that had previously fell of and i lost all turbo had rotted underneath and had a hole in it therefore no turbo, he got a new piece of pipe put it on and that was it all sorted. so i rushed home to get the tuning box back on it
    so its all better now jus need the simota back on it tommorow
    Quote Originally Posted by GARY3306 View Post
    Sometimes YOU jump to quickly.... I mearly listed them as the two most common faults that would cause those symptoms. Always a good place to suggest to a (normally) useless dealer. However, next time I won't bother trying to help. Everything on here is peoples opinion, I added my edit to avoid any confusion. Seems I was a little too slow
    Sunny Dartmoor
    Glad you got to the bottom of it mate.....
    Regular Member foyboy241177's Avatar
    May 2008
    eastbourne
    egr valve faliure and swirll flap faliure (new inlet manifold and egr valve)
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by foyboy241177 View Post
    Calm down big boy, read the thread its been fixed mate, you'll start scaring people with new manifold prices when its just a hose.
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. Loss Of Power On 3.0 cdti sri - please help
    By L.Hamilton in forum Engine & Drivetrain
    Last Post: 14th June 2011, 18:00
  3. Power Loss on 3.0 V6 CDTI
    By V6Andy in forum Engine & Drivetrain
    Last Post: 1st March 2010, 23:59
  4. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
