Results 1 to 10 of 17
Thread: Small Plumbing Question
    Regular Member Damian's Avatar
    Market Drayton
    Default Small Plumbing Question
    My toilet cistern has a plastic pipe which comes out of the bottom of it, through the wall then to the outside of the house. Some kind of overflow I assume.
    Anyway, mine is dripping outside the house, any ideas what this could be
    Regular Member simac's Avatar
    Wirral
    There is a simple adjustment you can make to the ball valve to stop it overflowing, it's a bit difficult to describe but you should be able to google it and find out what to do
    Regular Member Rob_the_Scot's Avatar
    London
    If it is the overflow, prob means your ballcock needs to be moved slightly to ensure the water is not flowing constantly
    Market Drayton
    I did google it and it came back with that.
    Wasn't sure if it was an overflow at first as it comes from the bottom of the cistern !!!
    norn iron
    an adjustment can sometimes do the trick, try the screw on the ballcock to lower the water level or if that fails you may need a new washer inside the ballcock itself
    Wirral
    Quote Originally Posted by Damian View Post
    There's lots of wierd and wonderful designs around these days, the close coupled ones just overflow into the pan and don't have the overflow pipe at all.
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    its the ball valve, they are easy to replace if you can turn the water off.. if adjustment doesnt do it, then pop inot wickes or other, not too expensive, i use a torbeck quiet fill, cost me around £8. takes about 20mins. Or ask a neighbour.. they may help... but wickes have a fact sheet instore.
    Market Drayton
    Think I have fixed it, there was a plastic adjutment nut and screw which pushes the water filling valve closed. I think it was overfilling as the water line was almost at the top of the overflow pipe, the water now stops filling about half an inch lower.
    FIngers crossed, or will try changing the ball valve
    Cheers all
    Wirral
    Sounds like you've sorted it
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    no problem, only only have to ask...
    Good luck... fingers crossed then!....LOL
  1. plumbing question - ball cocks
    By Caveman_nige in forum The 'Off Topic' room
    Last Post: 6th November 2012, 20:03
  2. Plumbing advice needed.
    By chrissri82 in forum General Chat
    Last Post: 6th December 2011, 13:56
  3. Emergency plumbing question
    By craigbarlow18 in forum The 'Off Topic' room
    Last Post: 4th January 2009, 20:58
  4. A small question
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2008, 21:33
  5. plumbing advice
    By John35 in forum General Chat
    Last Post: 20th August 2007, 22:02
