Results 1 to 10 of 11
Thread: Intermittant Limp mode
    Regular Member djr69uk's Avatar
    Midlands
    Default Intermittant Limp mode
    What would cause this? I cleaned out the EGR first time it happened a week ago and it was fine until yesterday then went into limp mode again. I left it 30 minutes and she's been fine ever since!?
    it's got to be plugged in to a diagnostic tool to find out whats wrong, really... avoid the cheap one's as they have been found lacking in the ability to read all the codes that could be thrown up..
    London
    It's a shame GM didn't see fit to have the same ability that Astra H's have to read the codes in the mileage display. Still that'd be too decent of them...
    Full Member Big Sig's Avatar
    Yeah, considering the Astra H was out after the Vec c...... Probably not worth the development considering it was to be replaced soon.....
    Regular Member foyboy241177's Avatar
    May 2008
    eastbourne
    egr swirl flap rod on inlet manifold fall off and egr valves sieze
    Midlands
    recently cleaned the EGR valve. checked the swirl valve rod and it is ok but feels slightly loose - probs 1cm movement back and forth. are they all like this or is it on its way out?
    Regular Member jonesy_ni's Avatar
    Co Antrim
    Can anyone recommend a code reader for veccy?
    One thats been tried and tested?
    Hope u get to the bottom of it mate
    i can thoroughly reccomend one, but it's not cheap....yet it does EVERYTHING that you could ever want it to do....
    www.ilexa.co.uk and look up their VAUX-COM range.. over £500 notes but it's the best you'll get apart from TECH2
    Co Antrim
    Over £500!!!
    Mmmmmmm, anything in the £50 price range
    Portadown, N.I.
    I can reccomend Opelscanner (canbus edition), but its around half the price of Vaux-Com, has less programming features for the new vec's, but is getting updated regularly with new functions. It reads all the fault codes on my vec C.
    Tim
  1. why does my eml come on and go off and go into limp mode?
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 13:48
  2. Intermittant limp mode....HELP!!
    By superfox233 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 10:55
  3. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  4. Limp mode!!!
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 14:20
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
