Thread: Swirl Valve
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Default Swirl Valve
    I'm having a new Swirl Valve fitted tomorrow. What on earth is one of those???
    What does it do? and Where does it fit?
    Just curious.
    Doug
    Dec 2005
    In the sponge-monkey tent
    I believe it's to do with the fuel injection system, swirls the petrol up before firing it into the cylinder so it burns better. Something like that anyway.
    Hemel Hempstead
    Is there just one valve, or are there four (one per cylinder)?
    Tell us what they do to your car Doug, and Piccies if you can.. Mrs Gsi has just bought that model of car and anything that yours needs.. if you get my drift..
    Leicester
    It is the valve on the swirl pot inside the fuel tank. It is to stop the engine from starving of fuel when the level is low and sloshing about.
    I have had mine done on my car. They some times stick.
    West London
    The swirl valves (one per cylinder) on the inlet manifold open and close under the control of an electrically driven Swirl Actuator which is mounted under the inlet manifold. They apparently help with cylinder filling efficiency. The connection between the actuator and the valves is a flat strip of metal which is "fixed" to the valves using little plastic ball joints which fail, leaving the strip flopping about on the manifold, connected to the valves whose joints have not yet failed. As this happens, running gets less smooth and consumption goes up. Eventually the ECU concerned registers that all is not well and puts the Spanner light on and the engine into limp along mode. This happened to my 1.9CDTi Estate (just out of warranty) and they had to change the whole inlet manifold with the valves and strip. They also have to change the actuator, not because it's faulty but for some stupid electronic/computer reason. Apparently the reason the joints pop off is because the valves get sticky with EGR generated gunk. They look pretty pathetic to me anyway and I think they fail for other reasons as well. It cost me a lot but my AA Warranty is going to pay for most of it.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    This is an old thread you've bumped. There is a how 2 so you can fix it yourself for a £1
    Sep 2009
    MANSFIELD
    I have a vectra cdti 150 06plate 100k miles.
    My garages computor shows fault p1109.
    Any body know what this means.
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
