Results 1 to 2 of 2
Thread: 2.2 dti cutting out in 4th and 5th
    May 2008
    mbro
    Default 2.2 dti cutting out in 4th and 5th
    As above my 53 plate vectra 2.2 dti is cutting out under load in 4th and 5th gear i have had the boost hose on top done as it was split car was going well for about 2 weeks then started cutting out again have been round all boost hoses and sprayed them looking for leaks none found had a good feel of the pipes all feel ok. I have looked at other posts but cant find anything but possible fuel pump. Am wanting to get it remapped but want to get this running problem sorted. Any ideas whats wrong and who should i take it to for a remap
    Hertfordshire
    This is only ever going to be a bit of guess work unless you get it on a code reader and have any stored fault codes read (DTC's).
    Assuming the boost hoses are fine, other common favourites would be MAF sensor, boost sensor or leaking vacuum pipes.
  1. 1.9 150 cutting out
    By japkadett in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 21:26
  2. Cutting out
    By Chuddy in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 22:37
  3. my car kept cutting out??
    By Curly7 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2009, 21:23
  4. 2.2 dti Cutting out
    By NBR in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2008, 23:49
  5. Cutting out!
    By Mike 3.2 GSI in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2005, 13:04
