Results 1 to 3 of 3
Thread: Help with rear quarter window
    Regular Member Itsallrover's Avatar
    Aug 2007
    in an M&S somewhere in the South West
    Default Help with rear quarter window
    Due to the trim having a large chunk taken out of my rear quarter window I have bought a new one off ebay.
    Any ideas on fitting? I can see some screw holes but thats about it.
    Any help appreciated.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Lift the boot carpet out and remove the trim clips from the rear edge of the side trim also the boot light if doing the n/s,then pull the trim towards the centre of the car and remove,to remove the pillar trim there's two torx screws on the lower edge and the airbag 'badge' needs to be pulled out (it's also a trim clip) then gently wriggle the pillar trim out minding any ribbon cables.Now you'll see the 10mm nuts holding the glass in undo the nuts and gently push the whole window out,VX recommend replacing the nuts which isn't a bad idea as they're only nylon.When dismantling watch out for any fixings i may have forgotten!
    Aug 2007
    Thanks for that one. Will get this done 2moro
  1. Rear quarter
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 19:36
  2. Fittin chrome window sills/rear quarter glass and a car smash!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 01:17
  3. Replies: 8
    Last Post: 9th September 2009, 10:33
  4. rear quarter window
    By willoftoon in forum Styling
    Last Post: 1st November 2008, 17:49
  5. Rear Quarter Window Problem
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 17:28
