Results 1 to 10 of 14
Thread: Cruise Control
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Cruise Control
    My dad has a facelift SRI CDTI, Im pretty certain its the stalk, unless someone has had a simolar problem and can tell me otherwise. When the cruise is activated, it just seesm to swicth off, anf then when you re activate it, it goes off again. Its really weird and does it very randomly, sometimes when you use it to move up a speed notch, it turn off on you. It does the same on activate and on resume. Is this a dodgy stalk or is there more to this?
    Sunny Dartmoor
    Spring on the brake pedal,there's a recall on this.......
    Birmingham
    Crikey, is that serious?
    Sunny Dartmoor
    Not really,here's a long thread on it.......
    http://www.vectra-c.com/forum/showth...cruise+control
    Birmingham
    Woah, that is a very long thread, will work my way throuhg it.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Thought the facelift would have had the mod done for the spring?
    I know I had the problem on a 2002 pre facelift so surely it has been sorted on the facelift.
    Birmingham
    Quote Originally Posted by glenboy View Post
    Will it need a dealer on it, or would you recommend DIY ?
    Birmingham
    Quote Originally Posted by merikiito View Post
    Its one of the first facelift ones, so they porbably put some of the old bits in it! So annyoing though, especially on a m'way when it suddenly decides to slow down. Can I reset it somehow, or shall I leave it to Vx?
    Sunny Dartmoor
    Get Vx to look at it mate,best bet,unless someone on here know's better.......
    the spring is easy to fit, as is the new stalk if its needed. Try driving with your toe lifting the pedal for a while, see if it switches off then. I had a new stalk on mine, it it wouldn't switch on. hth
  1. Cruise Control.
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 10th January 2011, 21:24
  2. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  3. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
