Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 112
Thread: Air Con STINKS!!!!!!!
    Birmingham
    Default Air Con STINKS!!!!!!!
    Hi people, as its been a scorcher of a weekend and the last week or so, I have had to use the air-con.
    However, although it blows loverly cool air, it stinks, sorry no, in fact it reeks, almost like cow poo.
    Any ideas what this could be, does it simply need a re-gas or does it need a soemthing more?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Sunny Dartmoor
    Have you changed the pollen filter lately?? could be that......
    Birmingham
    I havent changed anything at the moment mate.Is the pillen filter a DIY jobbie?
    Bye bye Vec B
    - Hello Siggy!
    Full Member Big Sig's Avatar
    Plus it could be caused by a build up of bacteria in the aircon evaperator. You can get aircon cleaner "bug bomb" type things that you let off in the car and it kills the bacteria that gives that nasty smell.
    Sunny Dartmoor
    Yes very easy,it located under the flap r/h/s bottom of windscreen,think its about a Tenner from Vx..........
    Birmingham
    would taht be covered ina service as its going in for aone in a couple of weeks?
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Would this eliminate the smell for all future uses of the air-con? It really is bad, its like a bleeding stink bomb.
    Bye bye Vec B
    - Hello Siggy!
    Yes it should do, think they are about a tenner from a motor factors. It should last you this year at least. It all depends on how much you use the AC really. The pollen filter may be covered in the service, they are changed every other time I think. Best call the person doing the service for you
    Birmingham
    Will do mate. Ill go and get some of that bacteria killer later. im not far from the famour AB Fletchers (known to most brummies), will give it a whirl. Are the results immediate?
    Bye bye Vec B
    - Hello Siggy!
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    hi ya.. i have one by Wynns one can does two doses..
    Wynns Airco Fresh.
    On ebay £11. can be found cheaper on local parts store. i use this its works a treat and is easy to do... very simple takes 2mins.
    http://cgi.ebay.co.uk/Wynns-Airco-Fr...2em118Q2el1247
  1. Clutch stinks...
    By strela in forum Engine & Drivetrain
    Last Post: 17th October 2012, 11:18
  2. My Cat Stinks!
    By ghostrider in forum The 'Off Topic' room
    Last Post: 4th January 2009, 19:14
  3. Air-Con stinks!
    By Taffyopel in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2008, 17:49
insignia recirc air intake where
