Thread: How do you undo the aerial plug?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default How do you undo the aerial plug?
    I'm replacing the aerial on the Vec as the rubber on the base has perished but come across a small problem. I cant see how to undo the wires in this plug. Any ideas guys?
    Jan 2006
    Skynet HQ EMEC#5
    If you look at this picture I took when I fitted the shark fin aerial:
    If you unclip the plastic from the roof, you should be able to see what's locking the plug in.
    IIRC, there is a part to press in with a small screwdriver to enable plugs to be pulled apart.
    Tyneside
    Have you got a part No. and price for the base please Rushy?
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Quote Originally Posted by mark1319 View Post
    I had mine replaced due to leaking, standard radio ariel, no Nav or DAB:
    Roof antenna
    G 13140081
    £34.66
    Vehicle : SRi
    Mileage : 137000
    Cheers for that Ian, a great help, might have to lower the headlining a bit more to attack it though. TKS again.
    Mark, im swapping it with my old mans as mine is totally perished and his ashtray is nearly full so the company will be providing him with a new one soon.
  1. What is this and how do you undo it!?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 18th June 2012, 16:55
  2. unable to undo any of my valve caps
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 22:18
  3. anyone want to undo the air box mod
    By ks246 in forum Parts for sale
    Last Post: 30th May 2009, 18:22
  4. Help - can't undo locking nuts/how do you remove spinning collar?
    By nigec in forum Suspension, Wheels & Brakes
    Last Post: 19th May 2009, 20:37
  5. Changing rear siggy springs, is this the bolt to undo
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2008, 04:44
