Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Lumpy idle on 2.2 Direct SRi
    Regular Member Palmo's Avatar
    Feb 2006
    Default Lumpy idle on 2.2 Direct SRi
    Anyone have any suggestions what may be causing an 04 2.2 Direct to have a 'lumpy' idle. It is not excessive, but noticeable - didn't used to do this. The car is well serviced and runs perfectly otherwise. It's almost as if the car momentarily misses a beat on tickover every now and again.
    Advice greatly appreciated. Are there any common problems that could be causing this?
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Possibly coil pack?
    Sounds as if it's missing a bit?
    Feb 2006
    Could this be the casue though, when it is only doing it on idle? Never misses when driving it, either lightly or under heavy load.
    Not sure if I'd describe it as 'missing' on idle either..... it's a strange one really. I've always thought the tickover was a little on the low side, although after some investigation I found this to be totally normal and in-line with other cars. It was never lumpy though like now - always a constant steady tickover.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Chain could have stretched a little? On second thoughts get some carb cleaner take off the air filter and spray the carb cleaner through the TB, the 2.2 can suffer a little from deposits around the butterfly, which wouldn't do anything when your foot is down but would show up on idle.
    Feb 2006
    Already had chain replaced as a precaution previously so can't be that.
    Does the 2.2 Direct Engine have an 'Idle Control Valve'? If so where is it located? Also does this engine have an EGR Valve? Again, if so where is this located?
    Vehicle : SRi
    Mileage : 137000
    Ive just edited my last post mate. Also the EGR is the barrel shaped thing on the end of the lump next to the battery box.
    Feb 2006
    On the right hand side of the engine? I thought that was the high-pressure fuel pump? Are we talking about the same thing?
    Vehicle : SRi
    Mileage : 137000
    EGR
    Feb 2006
    EGR
    Thanks very much for the prompt reply - really appreciated! I was thinking about the high-pressure fuel pump which is to the left.
    Do you know if these have an Idle Control Valve?
    Vehicle : SRi
    Mileage : 137000
    That one im not to sure off. Id clean the TB first, then disconnect (mechanically) the EGR and fit the VX blanking plate, just hang the EGR of of one of the bolts so that it can still work and not send car into limp mode.
  1. 2.0t edition 100 lumpy idle
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 4th January 2012, 17:02
  2. lumpy idle 2.0 turbo
    By tecg in forum Engine & Drivetrain
    Last Post: 14th December 2011, 21:21
  3. 2.2 direct lumpy idle, EML & TC lights
    By kensri in forum Engine & Drivetrain
    Last Post: 9th November 2010, 14:10
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
vauxhall vectra c 2.2 sri ideling
vauxhall vectra 2.2 sri not running right on idle
vauxhall zafira 2.2 auto lumpy tickover
