Thread: 2.2 Direct Engine Number Location
    Regular Member Palmo's Avatar
    Feb 2006
    Default 2.2 Direct Engine Number Location
    Can anyone tell me where I can find the engine serial number. Presumably this will be stamped somewhere on the block itself?
    Note: It is the location of the individual engine serial number I wish to find, not the engine code, which I know to be Z22YH.
    I wish to cross reference this with my log book to see if the engine is original, or at least tally's up with the log book.
    it's normally found on a sticker on the timing chain cover.. a big 2 x 3 " white label with a barcode on it..
    lets hope it's still on there..
    Feb 2006
    Mark,
    Had a good look today for this (whilst cleaning the Butterfly Assembly as per pther thread) and couldn't find any sticker on the Timing Chain Cover. Can you be more specific - is it high up or low down on the cover i.e. should I be able to see this from the engine bay, or from down below. I've tried doing both to no avail.
    Is the number not stamped into the block also somewhere. It's just I have my suspicions whether the engine is original or not. Would be nice to confirm it corresponds to the Log Book that's all.
    Martin
    Feb 2006
    Reckon I have found the answer.....
    http://www.speedsterclub.nl/bibliotheek/technische%20documentatie/tis/Standard%20Information/Engine%20and%20Engine%20Aggregates/00031629-Engine%20Identification,%20Engine%20Number.pdf
    ..... presuming of course the number on the Z22YH (2.2 Direct Engine) is in the same place as the Z22SE (2.2 Non Direct Engine).
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I have a different Engine from new in my 2.2 mate, I had to send the logbook away to get it updated, so now according to the logbook this is the proper lump. Why do you want to find out apart from the obvious? Your lump wont fall into the small oil jet category especially with it being a YH
  1. boot fuse location and number ( if possible)
    By valhalla in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 14:27
  2. boot fuse number and location
    Last Post: 24th December 2012, 13:05
  3. Thermostat location - 2.2 Direct
    By Big Dave in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 12:59
  4. Gearbox ident number location? Please Help!!!!
    By Ademusic in forum Engine & Drivetrain
    Last Post: 20th June 2011, 20:50
  5. Engine number location (Z19DTH)
    By lee gsi in forum Engine & Drivetrain
    Last Post: 5th January 2011, 13:02
opel signum 2.2 engine number
z22se engine code location
vectra c 2.2 benzin engine number
vectra 2.2 engine code location
opel zafira 2.2 engine number location
vectra c engine number location z22yh
how to check the engine number of an opel vectra 2.2 direct
where is the engine number on opel vectra c 2.2
engine reference in my 2.2 Vectra zdirect
opel vectra find engine code
