Results 1 to 10 of 25
Thread: Sensor
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Default Sensor
    Helppppppppppppppp anyone know where the cam sensor to the pump on a 2.2 dti is
    is it still playing up again Alan?..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    its in the pump...why what is the car doing ?..and what codes you got init ? ..
    all we're getting benny is the code for 'negative throttle deviation' when it stalls.. no other codes present.
    It only does it occasionally when it's hot..never in the first 5 -10 miles..which makes me think sensor and i've done dti's in the past which present as the same fault and they all came back to the cam sensor in the pump.. the fault presents as a surging at idle of 500 rpm above and below nautral idle before it stalls as it's unable to maintain an idling RPM..
    all boost hoses checked for splits and security ( no leaks) all vacumn hoses and lines are fine. no other faults on the vehicle either visible or stored in historic.
    It has been in for 'limp home' before, but that was down to the boost sensor being coated in oil sludge ( car has done 97K ).. sensor done and it's never faulted again..
    pick yer brains?..
    Feb 2006
    dudley
    it sounds like the throtle body to me we get this loads..the sensor on the back of the throlte valve (old type tps).on the body gets smegged and it plays the 5 volt referance feed up wich in turn gives the car loads a other faults...plus it has no feed back referance the ecu will move the flap during normal driveing if out of range can close it fully stopping the engine or restricting the air intake and the ecu doesnt know it is doing it ... ....
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Mark i havent done it yet was trying to find out part no and where it is so i can have a bash during the week
    Quote Originally Posted by benny View Post
    i'll take a look at this for Alan this week then.... cheers Benny....the only thing that slightly worries me is the total abscence of other faults with the car..But as the Boost sensor has been heavily smegged up in the past it's one i'm happy to follow..
    Alan.. free tuesday after work?..
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    yep mark your a top guy for helping me sort this out for me, think once its done ok i might get rid.
    Feb 2006
    dudley
    the throtle body tps sensor is sealed ..the way you can check it is to disconect the vac pipe to the throtle valve block the vac pipe then test drive it and see if it cuts out ...you may get other codes and problems but you will know they are faulty due to the pipe beeing disonected...
    Alan.. hows it running since the 'visit'......
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
