Thread: Fitting 12v in back of my Vectra Wagon
    Regular Member Peabrain's Avatar
    Apr 2008
    Purmerend (Holland)
    Default Fitting 12v in back of my Vectra Wagon
    Spend over a hour searching the forum because I was pretty sure I saw a thread on this with a picture of the connector and the partnumbers to order, but I really can't find it.
    I found the t-shaped connector in the (left) backside of my car and now I want to order the 12v plug. On the backside of the plastic strip you can feel the spot where you should place the plug. Is it difficult to remove the plastic part si I can drill the hole at exactly the right place ?
    Thanks for your help.
    are you trying to fit the 12v socket into the back of the centre console? or trying to fit one into the boot area?..
    Apr 2008
    Purmerend (Holland)
    Sorry , I mean the one in the boot area (left side).
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Can this be done in a hatchback as well?
    it sure can.. worst case is you buy the socket and the plugs not there.. all you have to do is probe out the rear electrical centre for either a switched or permanent live ( your choice) to pull power from and earth it either at the back panel's earth bonding point or use the REC's one..don't forget to add an inline fuse..
  1. Vectra C Wagon Canīt open trunk
    By daugaard in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2012, 22:29
  2. whistling noise after fitting turbo back sstem
    By tomo41 in forum Engine & Drivetrain
    Last Post: 17th August 2011, 22:52
  3. Auto rear level control on vectra wagon
    By zafira in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2011, 16:22
  4. Vectra c wagon subwoofer box measures
    By O-Peli in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2011, 13:45
  5. Not Vectra but Suzuki Wagon R question
    By Boy Lard in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2008, 22:12
