Results 1 to 10 of 17
Thread: Front Springs - How Much?
    Regular Member sophos9's Avatar
    Norfolk
    Default Front Springs - How Much?
    The missus has had some strange metallic knocking sounds from the front offside for some time now. Today I had to replace the starter motor so I thought I would look into the knocking, found the problem pretty quick!!!
    In the suspension seat I found about a 5inch piece of spring, great!
    So a I have a few questions!
    • Can I replace the springs without having to alter the geometry (i.e. remove shock from turret using springs compressors)
    • How much are stock springs?
    • Would a 2.2 Irmscher SRI come already with lowered suspension (i.e. if I buy aftermarket which lower by 35mm, they wont drop the ride height)?
    • Any recommendations on aftermarket kits?
    Thanks!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    it will be cheaper to fit a lowering kit on m8
    unless you car is still under warranty
    Sunny Dartmoor
    Norfolk
    Thanks for the replies! No warranty on car, all DIY!
    The car is a factory 2.2 Irmscher, aftermarket springs I'm pretty sure will be cheaper. I dont want the car sitting any lower than it currently is as it already does not like curbs n stuff thus the question on whether its already lowered (as advertised 35mm drops will not drop the car an additional 35mm)
    Quote Originally Posted by sophos9 View Post
    best bet will be to get the ebaich springs as they only drop to 30mm
    Norfolk
    Glynn, they will only drop if you do not have already lowered factory suspension... Do you know if the 2003 2.2 Irmscher comes with lowered suspension?
    i belive the ebaich springs are what irmscher use to lower their cars
    Sunny Dartmoor
    I didn't know they made a 2.2 Irmscher Vectra.........
    Norfolk
    You guys messing with me right?
    Here, there and every where!
    Eibach springs are around £140 for the set m8. Around 25-30mm drop on an SRi.
    The boys are jesting as Irmscher have never EVER made a car! They make body kits and styling accessories for Vauxhall's (and now Puegeots) but they ain't car makers
  1. Are front springs different..?
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 1st September 2012, 20:47
  2. front springs
    By porthy-t in forum Handling & Braking
    Last Post: 13th May 2009, 18:41
  3. front springs
    By iceeee in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2009, 09:25
  4. Front springs
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2006, 10:48
