Thread: vec-c heater
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default vec-c heater
    i have a clicking from this motor when heater knob is turned all the way to the left/cold. its located on the side of the heater box, whats its official name and as anyone purchased one recently any info please..also on how to remove the front panel shown on the left in pic i tried to remove but it seems stuck.
    it's one of the air servo motors...they are becoming a popular 'failing' part..
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    its still working fine but the clicking can only mean failure at some point i suppose!
    oh, it'll annoy the heck out of you long before it fails completely..
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    im out witting it for now-i try to remember to adjust the knob before putting the key in!!
    .. carry on..
    Sheffield
    Hi The Wizzard
    I had a similar prob, but mine would not work.
    To remove the panel, you have to undo that shiney nut, then the panel on the right will pull out far enough for you to access the other hidden screw.
    I disconnected the servo motor, removed it and then reconnected and it worked???????
    see thread - http://www.vectra-c.com/forum/showthread.php?t=47198
    Hope this helps.
    C@rlos
  1. no hot air out of heater. please help!!!
    By jonny22 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2012, 14:22
  2. Heater fan
    By ibbo in forum Bodywork & Interior
    Last Post: 22nd September 2011, 20:19
  3. heater
    By keith_johnson1967 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2011, 22:30
  4. heater is on way out i think
    By dan1983 in forum Bodywork & Interior
    Last Post: 30th January 2010, 13:53
  5. pre-heater
    By andrew m in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2008, 21:51
vecs heetar
