Thread: cat blowing fault
    Regular Member rickyroo's Avatar
    shropshire
    Default cat blowing fault
    Help is needed if posible.
    I had the AA come out couple of days ago as car wouldn't start.
    (oxygen sensor).
    Once replaced thought great off I went to work. When I started it in the evening to go home the car sounded like t was farting at me( blowing from the exhaust inside the engine somewhere.
    The AA man undid the three bolts attaching the Cat to the turbo to check inside whilst he was doing my oxygen sensor as he saw some sh*t around the edges, but he didn't undo the bolts underneath, he didn't move it that far only to the edge of the bolts with a screw driver.
    I have tried tighting them up but they are tight. Soon as it gets warm the blowing goes away comes back cold.
    Had a look this morning when started and white smoke coming from around the flange to the turbo charger / cat bolts on.
    Any ideas how to seal ths as their is no gasket don't want to use a sealing agent as could damage the cat and turbo.
    Help[ all out of ideas.
    Full Member Big Sig's Avatar
    Could you not make a gasket? otherwise take the joint apart and carefully give it a really good clean.
    shropshire
    just realised like an idiot, got lifetime warrenty on exhaust system from mij, going their in a while for them to sort out, cheers
    there is a gasket in there.. the cone ring in the turbo/exhaust joint is soft metal and it will provide the seal..avaliable seperatly..
    Tyneside
    Off this subject Ricky, but did you ever find out the problem with the backfiring? Was it to do with the exhaust in the end or other problems that caused it?
    shropshire
    it was vauxhall mark shock horror, fixed the fault eventually only bcause the turbo popped. The fault was the dc switching solonoid that controls the actuator, basically it wasn't working and making the turbo not boost correctly.
    Also when vx put my sparkplugs in they didn't even read the box were it says "plug gap to be et for specific model" they didn't bother and just chucked them in so instead of being at 1mm they were all different creating misfires, the list of f**k ups from them was unreal, once I started fixing it myself I haven't had any problems with it for nearly a year, except for the cat & oxygen sensor which is now fixed, as the aa didn't seat it properly
    are you having problems with yours backfiring?
    Tyneside
    No just going to MIJ to get my exhaust made soon and was getting worried if the exhaust had caused the problem
    Good to hear your getting some better luck now mate
  1. Heaters only blowing hot air??
    By vectra2004 in forum Troubleshooting
    Last Post: 13th March 2013, 18:59
  2. 3.2 Gsi manifold blowing.
    By Tennants in forum Engine & Drivetrain
    Last Post: 21st March 2010, 20:31
  3. blowers and ac blowing hot air
    By Baz4u2me in forum Troubleshooting
    Last Post: 27th January 2010, 15:17
  4. only blowing hot air
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 13:19
  5. Heater only blowing Hot Air
    By DaveVectraSRI in forum Troubleshooting
    Last Post: 22nd February 2009, 15:47
