Thread: alternator pulley squeak.
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    Default alternator pulley squeak.
    hi guys,
    just to put my mind at rest, took my aux belt off this morning as the car has been noisy in idling. still noisy with belt off and when i spun the alt pulley with my hands it squeaks a little. has this had it or is there a quick fix?
    Also had the cambelt changed a while back and the water pump changed recently and the engine still sounds a bit rough around that area.
    any ideas would be appreciated and also if anyone has had these problems could you give me an idea on any costs if possible.
    cheers and thanks.
    kev bux.
    Regular Member rickyroo's Avatar
    shropshire
    had mine done last year buddy same fault on 20.t vauxhall said there was like a clutching plate service pack to buy (basically the black wheel you put the belt over) ask the dealers mate.
    when the cambelt was done, did they change the idler/tensioner pulleys as well, as if they didn't then they should have. if the noise is there without the aux belt on then the noise has to be coming from behind the cambelt cover.. if the waterpump has been changed and the belt has been done without the rollers then i'd be taking the belt off and seeing if the bearings are failing ( not uncommon hence why VX say they should be changed with the belt)..
    Jan 2006
    BOROUGHPETER
    thanks, i will ring them monday and find out if the idler/tensioner pulleys were changed when cambelt was done then. if not then i presume they will be changed free of charge then or not?
    thanks. kev bux
    they will more than likely not change them FOC, as they could claim they were never instructed to fit a full kit..and you can't prove either way....
    Jan 2006
    BOROUGHPETER
    great, any idea on costs?
    kit would be £70....about 1.5 hrs to fit....
    Jan 2006
    BOROUGHPETER
    thanks mate, top man.
    will keep posted to let you know how i get on with them monday.
  1. Alternator pulley - replacement has finally arrived
    By Caveman_nige in forum Engine & Drivetrain
    Last Post: 21st July 2017, 18:32
  2. squeak squeak squeak squeak drive belt
    By martygibson1888 in forum Engine & Drivetrain
    Last Post: 8th February 2013, 17:20
  3. alternator clutch pulley
    By SWEED in forum Engine & Drivetrain
    Last Post: 1st July 2010, 13:34
  4. Alternator rattle - new clutch pulley 93182514?
    By charlie in forum Engine & Drivetrain
    Last Post: 28th April 2009, 17:43
