Results 1 to 3 of 3
Thread: Changing Injectors???
    Tyneside
    Default Changing Injectors???
    Right first of all should I even attempt to do this myself or is it a job for a mechanic? Can't get home so I might have to pay somewhere, but I want to avoid that at all costs obviously.
    Is it difficult? Is there any precautions that need to be done? Any dangers etc?
    This explains how to do it and seems simple enough LINK
    It's a very good guide for how to do it..I did it slightly differently when we swapped the injectors when I fitted Duncan's stage 3 kit..the salient points carry over thou... just be prepared to loose coolant, undo loads of tiny torx fixings and have a spill of fuel..
    to depressurise the fuel rail, wait about 30 mins after running the car to let the pressure leech out of the rail..
    follow that PDF in the link, but a couple of points.. make sure all the injectors line up with the rail when you put them back in..if you nick an O ring you've gotta change it.. there are locking tabs on the injector harness's plugs that you have to release before you can remove them.. not easy to see and hard to get to..
    work slowly, and be paitent.. it is doable 'at home' if you take your time
    Tyneside
    Cool cheers Mark
  1. 2.0t injectors
    By mann3210 in forum General Motoring Chat
    Last Post: 1st January 2012, 15:27
  2. Injectors
    By signumboy in forum Engine & Drivetrain
    Last Post: 28th September 2011, 21:23
  3. Injectors?
    By BigWilko in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:27
  4. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  5. Engine dead-after changing injectors - any ideas?
    By Sch3cter in forum Engine & Drivetrain
    Last Post: 8th September 2010, 12:55
